427 help
You should read up on dynamic compression, then pick a combination that will give you around 8:1 to 8.5:1 dynamic compression.
I'm building a 468 right now. First I chose the rpm range I wanted, then the cam that will get it there, then the pistons that will give it enough dynamic compression to run there. What it's ending up at is 11.1:1 static compression and 8.2:1 dynamic.
This engine is going to replace a 427 based 438 that was running 11.4:1 SCR with a big solid cam to give it 7.6:1 DCR. This engine would run 11's on pump gas and rev close to 8000 rpm.
The method we use is with the deg wheel is while turning it in a clockwise direction at 4* to 15* dependes on your cam the valve will be at its closest to the piston the intake is going away from the piston --- but the exhaust is coming twards the piston .100 is the spec jz
stock valves brake off all the time stainless will some times only bend you understand how to check it now jz
I'm going to use stronger springs with a comp cams .595 lift solid cam. The stock valves should be alright as long as there is no contact right?
https://ls1tech.com/forums/eastern-members/517917-super-comp-super-street-bbc-cars-shop-today-pics-vids.html
