Need expert engine advice for 327 build
Oh yea, one more thing. Also using the Victor Jr. intake along with a Speed Demon 800cfm carb. Sorry.
And to the second response: This is a 75% strip/ 25% street truck. You say I should go with a lower LSA but according do the pro's, that will decrease my HP. However, thicker head gaskets might be better. I really think I should go a different route with the cam...
dont resort to thicker head gaskets,manupilate your DCR with valve events and go with as much as SCR that will allow the use of pump gas,and appropiate timing for both street and track, pinging or knock should not take place if u make a few calculations and have proper quench
go with a cam that will maximize your heads thru out the power band
Last year i would agree ( todays fuel at the pump ) but he said his static is 10-1/2 that was the reason thicker gaskets Stop the ping ????? ( first no )longer duration will only work up to a point its a street car as i see it jz
