Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
what size carb??
Old Jul 16, 2006 | 02:41 PM
Russell1337's Avatar
Default what size carb??
the motor is a 93 chevy 350 from a 3/4 ton van
i have the motor in my boat now
whats done to it:
full rebuild with clevite bearings
rv/marine camshaft
HEI distributor w/ vacuum advance
center bolt valve cover heads (are these vortec heads?)
full marine gasket set
brass freeze plugs
stock intake manifold from the old 305 "modded" for the fuelie heads
now the motor wont get above 4000rpms. thats with 10 people in the boat or just me by myself. it gets up to 4K almost instantly after you nail the throttle. this leads me to believe im running out of fuel. my cam is good to around 5700 or so.
i have the stock marine quadrajet taken off the 85 305 motor that came in my boat.
im wondering what size carb i should try. someone gave me a 650 marine carb (holley or edelbrock not sure which one) that has a bad accelerator pump. i havent gotten around to trying it yet though
also, would i see much of a power increase with an aftermarket intake manifold as opposed to the stock one, that is with the right sized carb
also, can anyone estimate a ballaprk figure for how much HP this engine should be making? im not the most knowledgeable on chevys as im a ford guy
thanks,
Russell
Old Jul 16, 2006 | 05:09 PM
2005suburban's Avatar
I would do a 650-750 cfm..
The holley 750cfm Double pumper is good to I want to say 6000-6500....
So that should be plenty
As for the intake manifold..
The weiand xcelator is a great manifold and it complements the holley 750 very nicely!!
Old Jul 17, 2006 | 12:43 AM
Nate81Camaro's Avatar
you said
"stock intake manifold from the old 305 "modded" for the fuelie heads"
did the manifold from the 305 fit onto it?? I dunno if you're planning on putting it on, or if you've done so already.
How many bolt holes do your heads have? They made centerbolt valve cover's that weren't vortec heads (if I'm thinking correctly - lil intoxicated, but still typing pretty good )
let me know, and I'll let you know
Old Jul 17, 2006 | 08:39 AM
buttermantoast's Avatar
Look at the intake manifold they wont have bolts in the middle on vortec jus in the corners and they bolts will be straight not angled
Old Jul 17, 2006 | 07:12 PM
ok i got the 4 center bolts but they are on a different angle than the old 1 piece rear main 305 the intake came from
Old Jul 18, 2006 | 08:44 PM
Tiresmokin's Avatar
Vortecs came out on trucks in 96. I doubt you're gonna rev an rv cam to 5700. More like 5000 to 5200. The quadrajet would work fine. A 600-650 cfm is all you need. You don't need more cfm unless you get a bigger motor or turn your 350 at a lot more rpm's.
