Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Points distributor, 1 or 2?
Old Jul 22, 2006 | 02:51 AM
Bowtie Boy's Avatar
Default Points distributor, 1 or 2?
I might be in need of a new distributor, if I do does it matter if I get a 1 or 2 point dist? Is there a difference or specific reason for one over the other.
Old Jul 22, 2006 | 02:47 PM
johnjzjz's Avatar
A Single Set Is Easyer To Tune The Double Set Was To Have A Greater Spark Length No High Amp Ignition In Those Days You Will Need A Dwell Meter And Solid Core Wires But You Radio Will Buzz Hhahahahaha Jz
Old Jul 25, 2006 | 11:00 PM
shandy294's Avatar
My first car had a dual point distributor (71 340 Dodge). I just set each set of points and didn't worry about individual or total dwell. If each set is gapped correctly,it should work fine (for that type of not-so-good ignition system).
I was told the dual point eliminated the effect of point bounce at higher rpms.
Unless you want a points ignition for stock authenticity,I would upgrade to a better system.
Old Jul 26, 2006 | 12:06 AM
Bowtie Boy's Avatar
I was thinking of going with a basic HEI, how hard are they to wire up, im not to good with wiring at the moment, slowly learning.
Old Jul 26, 2006 | 05:30 PM
johnjzjz's Avatar
wiring is very simple dont let it get to you, its like a water hose has to be conected at both ends hahahhaa a HEI GM dist is a one wire and if you have a tach its 2 the cap has a plug that conects to the base thats it your existing wire might be a resistor type wire so go to a key on power source and conect it their tape off original hot wire to the original coil, it some times goes to and from the starter but thats not important, all you need is a power that comes on and stays on when cranking and after the ignition switch is in the on posision thats all an HEI needs jz
Old Jul 26, 2006 | 05:38 PM
johnjzjz's Avatar
the early Mopar distributers only had 4 lugs on the point cam not 8 like the one you had the 8 lug is easer and you can just leave out the one set if you fase the cap to rotor location easy to do but thats not what he is doing jz
