Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Any horsepower estimates?
Old Aug 17, 2006 | 11:32 AM
Stroked SBC's Avatar
Default Any horsepower estimates?
I put together a really good combination on a 383 that before being dyno'd, all the local hot rodders that were there were making their power estimates on as usual. I thought it would be fun if you guys wanted to put some of your knowledge and experience to a little test and see how close you could come. We had alot of fun doing this at the shop. Here's the build.
Bore = 4.030
Stroke = 3.75
Head are ProTopline Vortec replacement ported and flowing 280 cfm@.500, and 285@.600 intake and 190@.500 and .600 exhaust without pipe, and . 2.02 & 1.60, estimate port cc's at 180.
Compression is 10.8-1
6.125 h-beam rods
Forged lightweight flattop pistons
Edlebrock Super Victor type intake with plenum smoothed some.
Cam is solid street roller single pattern 244 @ .050 and .591 net lift with 1.6 rockers on 108 lc installed at 108 cl
950 cfm HP carb Super sucker 1 1/2 " spacer
1 3/4" 34" dyno headers with about a 15" 3 1/2" collector.
ON PUMP GAS 91 super
On an engine dyno SF901. Electric fuel and water pump.
I'll post numbers latter if anyone is interested in taking a guess at it. I just wanna see if this is as much fun as we had at the shop, not to try and make anyone look stupid. Only one guy here came close besides me. Even the guy that owned the dyno.
Old Aug 17, 2006 | 12:05 PM
white_ta's Avatar
I'm gonna say 455 hp.
Old Aug 17, 2006 | 02:18 PM
YenkoST's Avatar
I'm going to say about 575-600hp and 550 ft lbs.
I say that due to dynos I have seen with 383s, 195 AFR heads, and a 230/236 cam putting down 520 hp.
Old Aug 17, 2006 | 03:22 PM
NoFive0's Avatar
435??
Old Aug 17, 2006 | 03:47 PM
1FSTZ71's Avatar
Old Aug 19, 2006 | 12:33 AM
Here's how it ended up.
Peak torque was at 4700rpms and it was 527 ft.lbs
Pear power was at 6300rpms and it was 542.
What was interesting was torque down low,
3100=441 ft.lbs
3300=446 ft.lbs
3500=455 "
3700=475 "
3900=503 "
4100=513 "
4300=523 "
carried over 500flt.lbs till 5500
Old Aug 19, 2006 | 09:39 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Not too shabby, what is it going into?
Derek
Old Aug 19, 2006 | 09:59 AM
YenkoST's Avatar
Well....I was a little on the high side....not bad....I would have though it would have made more with the higher compression and bigger cam.
Old Aug 20, 2006 | 01:16 AM
Actually I sold the motor to a guy who said he was going to put it in a 1/2ton 4X4. That should be kinda fun.With a little more agressive cam and some intake work I may have been able to push it up around the 560-570 mark, but it would have taken more head work to get it above that. I actually built the motor to get rid of some parts that I had laying around, and to get enough money to buy my flow bench was the main reason. And to prove to the guy that I was working for that he was taking the wrong approach to building his engines. His last two 12-1, 383's only got up to the 515hp mark, and he was happy with that.
I'm curious if anyone else has a dyno'd engine that the rest of us could take a stab at. It gets to be a big thing around here on dyno days. The only thing we haven't done yet is to make a board and start taking bets. But I have won a few $$$ on the side.
Old Aug 20, 2006 | 01:17 PM
7 Second Club
I can always do a dyno challenge, but it would be a chassis dyno and not an engine dyno. I'd like to see what my next bullet loses between the engine and chassis dyno, so that might be a interesting side note.
Derek
Old Aug 30, 2006 | 03:43 PM
jumpmanmb87's Avatar
How about this combo what you do think it will make for numbers and any suggestions about it
Bore = 4.030
Stroke = 3.75
Scat 4340 Forged Crank
Scat 4340 Forged Rods - 5.7length
SRP Forged Pistons Flat Tops 11.0 compression
Dart Iron Eagle Platnium 200cc or 180cc with 2.02/1.60 angle plug
Comp Cams Xtreme Energy Flat Tappet 284/296 .507/.510
Comp Cams Magnum Roller Tip rocker arms 1.52
GM Lt1 Intake comparable to (performer rpm)
GM 70 Corvette Quadrajet (Jetted)
Not the most powerful thing but im throwin some combos together
Old Aug 30, 2006 | 07:02 PM
NoFive0's Avatar
How much to the ground though is what I want to know. Good numbers though. Tim.
Old Aug 30, 2006 | 08:51 PM
Cali99SS's Avatar
Did you use a tall deck block? If not how did you get 6.125 rods to work? 1" compression height pistons?
Old Aug 31, 2006 | 01:09 AM
Yep 1.000" I normally wouldn't have done this but I picked up the rods cheap.
Bore = 4.030
Stroke = 3.75
I'm not sure about the intake and carb combo, but with everything being ideal with the 200 heads I would give it around 485-490 hp and with the 180's probably about 470-475. I think the intake with be the biggest question.
