Head Discussion
I went from a set of mildly ported World Products Sportsman II iron heads to a set of Canfield aluminum heads. Both 195cc, but canfields had nicer bowls and chambers (only 1 hour clean-up work), and used 2.05/1.60 valves instead of 2.02/1.60. Picked up 2-1/2 tenths in the 1/4, and about .05 of it is in weight savings.
Weight savings, can run a higher compression rating with pump gas on aluminum versus iron (I'm currently at 11:1) without detonation if cooling system and tune are good.
Good luck whatever route you go, there are tons of options!
Derek
Thanks for all the help im just trying to get as much info so i can do it right the first time. Experimentation is great but im workin on a budget so im cautious of everything
Your existing heads are likely okay, but 30+ year old technology compared to today's stuff depending on casting # is of course nowhere near as good. A friend of mine runs a speed shop and we've seen 20-30 rwhp gains from GM casting heads to aftermarket heads, and sometimes even more! A set of 461/462 "camel" or "double-hump" are some of the better cylinder heads from the 60-70s era, but are blown out of the water stock to stock against a set of dart iron eagles or world sportsman II heads. Porting will help, but I'd save the $$ and buy a set of newer heads, but again I'm only one opinion.
My current 475 hp combo is this (guessing 475 based on weight and rwhp #s):
# 3970010 350 4-bolt main block .060 over (388 cubes, but most people know what a 383 is so I tell them that instead)
Eagle cast crank, SIR rods
TRW forged pistons flat tops (approx 11:1 compression)
Crane solid cam 518/536 lift 230/238 duration @ .050
Canfield aluminum 64 cc heads (195cc 2.05/1.60 valves), no porting
Victor Jr. Intake with no porting
750 Holley HP double pumper carb (a 650 double pumper std Holley is about a tenth slower if both are properly tuned, and about $250-300 less)
1-3/4 Hedman headers
3" Magnaflow full exhaust with tailpipes
372 rwhp at tires N/A, times in sig at 3500 lbs on pump gas.
Derek
Good luck!
Derek
The only heads I would stay away from is the World Products heads. With porting their as good as most, but out of the box arent much better than a stock Vortec flow wise.
But thats just my 2 cents.
Im really leaning towards the iron eagle platniums or the the pro 1 heads lemme know what everyones thoughts are or should I get something else. AFR's are outta the picture because of price but these darts really arent that bad.
I will reduce my cylinder head price for Christmas to $1050 with shipping. PM if you are interested.
I have the 230cc Pro 1's on my 396 with a .620" 254 Dur. @ .050" solid roller and shift at 7000... 3350lbs ran 122mph so far with more to go. that was with gearing for nitrous,etc.
you'd make a lot more than 450hp though...
As far as the old angle plug heads goes, I have run low 13's with stock 1.94 cammel humps (462) and a 218 at .050 cam with only 9.0 to one on a 350 in a 4 speed 55 Chevy. Your slant plug heads are a little better than those. They are probably 292 castings. They are similar to my Bowtie heads only they are most likely torquier. In a 9 to 1 compression application, I ran high 12's all motor in my 55 Chevy with those and the old "30/30" cam. I had a TH350 with 2800 stall and 4.11 gears. Seems you could do better with a little more lift and a little less duration. You can get a cam like that for $130 or so. Just to keep the money spent in perspective compared to the benefit.
Have Fun.
Henry
