Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Help?
Old Aug 26, 2006 | 10:32 PM
Nemo02Z's Avatar
Default Help?
Got a question but not sure where to go to ask so here we go. we have a 97 4.3 motor out of a gmc pick up, stupid us we did not mark the rods when we dropped them out of the motor, no big deal we thought, now that we are putting them back in we get them in torque them down to about twenty pounds or so and the crank will not turn over locked tight. we know its not the crank, we thought it might be at first so we got another one, now question is this, theses rods have gma and gmb stamped on them is there a certain order they have to go in or do you think that since they use heat to put the piston back on the rods they warped the rods.
Old Aug 28, 2006 | 10:57 AM
Adrenaline_Z's Avatar
I bet you have the non chamfered side of the rod backwards and it's binding
on the crank.
Look at the big end of the rod and you'll see one side is machined. The chamfered
side goes against the counter weight.
Old Aug 28, 2006 | 01:33 PM
Nemo02Z's Avatar
Okay I will look at them. what about the rod caps not being put back on the exact rod the came off of....
Old Aug 28, 2006 | 02:25 PM
Not unless the cap is installed with the chamfered side reversed (which would
be easy to see).
Have you installed new bearings and clearanced the bottom end? Did you have
the connecting rods checked and machined as necessary before installing them?
Old Aug 28, 2006 | 04:25 PM
Nemo02Z's Avatar
Yep most parts are new the block just came back from the shop so clearances are good, for the most part we know it has to do with the rods and since nothing was labled we are gonna have to go at it by trial and error, and keep switching rods and caps. which with the info you gave me it will be easier. thanks
Old Aug 29, 2006 | 11:03 PM
Nemo02Z's Avatar
on the crank.
Thanks for the info we finally figured this out,we were putting the caps on the wrong rods, since they were noy labeled when they went to the shop, we had no idea which ones went on what rods so when we torqued them down they were binding. stupid mistake will not happen again....
Thanks again
Old Aug 29, 2006 | 11:14 PM
Nice, thanks for the update. Good to see it was nothing major.
