Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Will parts swap?
Old Oct 11, 2006 | 11:10 PM
RelentleZ's Avatar
Default Will parts swap?
I have a 5.7l 350 out of an early 90 chevy pickup and would like to rebuild it and sell it for my other engine build. I have all the internals from a 95 lt1 and am wondering if they will work/fit in the truck block. Any ideas?
Old Oct 12, 2006 | 12:16 AM
machinistone's Avatar
Yes crank and rods can interchange- LT1 cranks are balanced lighter so get LT1 replacement pistons rather than the standard cast replacements. You will notice the counterweight is drilled/notched differently.
Old Oct 12, 2006 | 12:17 AM
fast377's Avatar
Yea, they will work. The casting number on the lt1 crank is the same as your tbi block. Rods are different, but one can be used in place of the other. Cams will interchange also.
Old Oct 12, 2006 | 10:34 AM
RelentleZ's Avatar
thankyou guys for you help
Old Oct 12, 2006 | 10:12 PM
RelentleZ's Avatar
how about the cam and lifters? the lt1 had rollers and the 350 does not. can i use the rollers and lt1 cam in the 350?
Old Oct 12, 2006 | 11:20 PM
82whitez28's Avatar
uhmm the cam will work but does not have the lobe for a mechanical fuel pump... and the lifters will work as long as it is a 86 and later block i beleive....
