Reverse Flow cooling... Dry intake... questions
I want reverse flow cooling because I can run more boost or timing on a given grade of gasoline. So what does it take to make a reverse cooled SBC?
And I do not want any coolant flowing through the intake if at all possible.
Anyone have tips or ideas?
http://www.lt1intake.com/files/swapping.htm
if i cant have a dry intake i dont care... and the reverse flow cooling would jsut be a plus... there are far more reasons for me to go to the SBC than not to (like the fact that if it says "lt1" on it, it's going to cost more.)
We drill a hole in the front of the heads and tap for a -12 hose. You will either have to buy or build a manifold to replace the stock H2O pump. We do use an inline pump.
So mount the pump near the radiator output, pump into head, thru block, out of manifold, back into radiator. Obviously -12 hose is very expensive, and the fittings are nuts. If you want it cheap, try rubber. If I missed anything, write me, or someone will probably catch it.
Now you used a inline pump for your water pump... any suggestion on what to use (consider space a concern and this will be a weekend street warrior... so can't have something that isn't reliable). And what can I do for a waterpump manifold... links or suggestions would help a ton.
Thanks a TON... this was probly the most helpful post I have ever read on LS1tech. lol. Thanks again.
FORGOT TO ADD... if This were on a half filled block... would it cool well on a street driven vehicle? I know that is pushing it (somewhat), but people seem to have great luck with the half fill on street cars. I figure the Reverse flow cooling would only compliment that.
They make reverse flow pumps for the SBC.... would that work the same?
Sounds like there is more options than i thought there was going to be.
How do you know where to drill holes in the head? Just kinda "knowing" where the coolant passage is and drilling in that area?
