Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
sbc vs. LS7
Old Nov 13, 2006 | 03:51 AM
smokin2002's Avatar
!!! Do you really need that much flow!! its possiblae to have to much head esp on a small block, 400cfm should be expected for well over 500+ci motor. my 496 will only have 325cfm heads, if you go too big you have to turn the **** out of the motor.. i couldnt even imagine on the street. depends on how big of a small block your trying to go i guess. i know you can touch a 454 SB with an aftermarket block. anyway i think 400 is a lil much.. just me though.
Old Nov 13, 2006 | 07:16 AM
Street Lethal's Avatar
Originally Posted by Quickin
Aren't there sbc heads that flow into the 400's?
There have been two valve per cylinder SBC heads known to flow extremely well, in comparison to a four valve per cylinder one. I just tossed in the Aero head concept because the factory LSX heads are potentially that good, and we needed a fair comparison...
Barry Grant introduced a three valve per cylinder head at the SEMA show back in '04. I honestly haven't found the time to research the development on it, but with it supposed to be that cost-effective, it should be able to release the full potential of any SBC configuration, including the forgotten TPI, and pathetic TBI designs...
We shall see though...
Old Nov 13, 2006 | 03:40 PM
Quickin's Avatar
Well, the problem with the LS7 engine is the LS7 intake, it holds the heads back from flowing to their potential. I would never use an LS7 intake. It would be a Hogan/Beck type or the Harrop Hurricane.
So yes, I would think the more flow you have the more power you'll make, given the correct amount of cubes. I started getting parts together for an LS7 build, resleeved block. 4.155 bore x 4.000 stroke...434ci. Or go with a 4.125 stroke....447ci. Either way, as much flow as possible will help.
But I was figuring maybe going with a sbc instead of LSx....IF they can make more power than an LSx engine for a daily driver. Thats why I started the thread. I would have NRE build it.
