Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Cooling for 95 Z with BBC
Old Nov 9, 2006 | 06:28 AM
cwaldt's Avatar
Default Cooling for 95 Z with BBC
I'm about to order me a radiator. I wouldn't mind getting one of those radiators used in the turbo setups. The ones that stands up straight instead of leaning towards the engine. I know you have to cut out some to make those work. If anyone knows where to get those let me know.
Also my other choice is just buy a radiator and place it in stock location. I wouldn't mind the turbo style radiator just for more room. But my question is would a 26x19" overall & 20x17.5" core radiator with 2 row 1" cores be enough to cool my 454?
Old Nov 13, 2006 | 06:44 AM
cwaldt's Avatar
Nobody's got a BBC in there car that can tell me what size radiator they used?
Old Nov 13, 2006 | 07:15 AM
jshiver's Avatar
I am going to use the Summit universal 31"x19" two-row radiator on mine. Why? you ask...I have it laying around from a previous project. I think it is the same size as the stock radiator except thicker.
Old Nov 13, 2006 | 07:54 AM
ulakovic22's Avatar
How good was the stock LT1 radiator/fan setup doing? I would think a Griffin/BeCool replacement radiator with the stock fans should do the trick, but I don't know. Look at truck radiators and how big they are, I think in general they are about the same size, maybe just thicker, not sure.
Old Nov 13, 2006 | 09:03 AM
cwaldt's Avatar
I've got a truck 454 radiator and its too huge. I'd have to cut 2" on each side of the frame rails. As far as the LT-1 radiator I got rid of it because of all the other connections on it. I just wanted to go with a different one for a cleaner engine compartment.
Old Nov 13, 2006 | 03:21 PM
smokin2002's Avatar
cool, im going to try my original design Ls1 radiator setup with the dual fans and electric WP , just because i had bought the Bigger SLP Radiator, if it doesnt cool ill go the same route. Track should be fine but i want it on the street from time to time
Old Nov 13, 2006 | 06:07 PM
ulakovic22's Avatar
What truck did it come out of? I didn't think that they were that much bigger.
Old Nov 14, 2006 | 06:45 AM
cwaldt's Avatar
I came out of a 1 ton Chevy truck. I think it was an older truck though and that may be why its so much bigger.
Old Nov 15, 2006 | 03:57 AM
Cop Car's Avatar
put some plugs in the LT1 radiator.
the SLP "upgraded LS1 radiator" is just an LT1 radiator.
Old Nov 15, 2006 | 02:07 PM
Strokinit383's Avatar
I have an lt1 radiator on my 383 and it doesnt seem to keep up in temps above 70. With high flow water pump, 160 deg thermostat and the lt1 radiator i run at about 200 deg when its about 70 outside.
Old Nov 16, 2006 | 12:31 PM
ulakovic22's Avatar
Yeah, I would stay away from an LT1 radiator. I think they are a little small for a conventional system. With a reverse flow and being able to stay in the radiator longer and also going to the heads first. Conventional flow hits the hottest part last and also gets pushed pretty fast through the radiator.
Old Nov 18, 2006 | 10:05 AM
smokin2002's Avatar
Good info, ill keep that in mind before i take it out for a good drive for the first time.
