Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
18* Heads
Old Nov 28, 2006 | 02:07 PM
raceking33's Avatar
Default 18* Heads
Hey I have a quick question for you motor guys....... I am going to be running 18* heads on my new carbed 383 build and I was wondering do I have to use 18* pistons or is okay to run just the standard flat tops like 23* ones? is there a difference? THANKS!
Old Nov 28, 2006 | 03:39 PM
68maro's Avatar
7 Second Club / STF Veteran
big difference
Old Nov 28, 2006 | 03:46 PM
jmm98LS1's Avatar
yup, valve reliefs need to be for 18*
Old Nov 28, 2006 | 09:19 PM
spray's Avatar
Ross has a flat top that serves both valve angles. They work well but it is the only one of its kind I believe. I have run them. Ross even says and I used more then they said I should that they will hold 250hp of nitrious. look them up...they were a good deal.
Old Nov 29, 2006 | 05:35 PM
blown454ss's Avatar
i've been trying to find some 18* pistons with 8.0-1 compression for about a month now. its going to be a custom job from dimond pistons, about 1000 bucks
Old Nov 29, 2006 | 08:45 PM
TwoFast4Lv's Avatar
Yes for low CR they are custom. I had a set of Wiesco's for my 18* heads that did both 23 and 18s
Old Nov 29, 2006 | 10:21 PM
SHAKER's Avatar
when done check p to v it is crucial when doing changes like this
