383 crank question
I need to buy a 3.75" crank...but dont know exactly how long are my rods...do to the fact that i bought the 383 stroker used...
So the question is...If i buy a crank that says for 5.7" rods or longer...so this means that if my rods are 6" it should work?.......
So why do they have another crank that says for 6.0" rods or longer....?
would the first crank i mention work with a 5.7" rod?
Please help...need to buy the crank as soon as posible.
Any 3.75 crank can be used with any rod if the piston has the correct pin location and the rotating assembly is properly balanced.
so i can order the 3.75" crank that says 3.75" rods?
thanks for the reply
It tells you what rod will clear.
You can never assume anything. The crank, the rod, the piston & the deck must be checked by someone before you buy anything.
I would not gamble with a cast piston on N2O. The rods are iffy at that level also,
get them mag'd and new bolts at a minimum.
