distribuitor options for BBC
It's nothing special, standard low profile dist. We use crab cap on my tunnel ram motors or standard cap on single dominators.
Found some more, but they won't load. The standard cap rubbed so we switched to a crap cap.
I was going to try an Msd HEi distributor for my big block. havent quite got that far yet though, if you take the cap off inside the engine bay it should clear in and out fine. i cut the firewall away under the plastic cowl for more room.
Just my opinion. If you have room, we are really pushing tunnel rams. All the motors we have switched have been flying, 50 ish HP no other changes, I will never use a single carb again.
Good luck.
That .950 cam is not even my biggest. The heads for my 705" came with a 1.050, I ended up giving it back, that thing scared the hell out of me.
I can't stress enough, combination comes 1st, don't try to get the biggest cam, biggest carb ect. It's all in the combination. Don't fudge anything when ordering it will only slow you down. I still vote tunnel ram.
Good luck.
how about the victor jr for bbc, or a weiand team g?
