Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
400 chevrolet sb?
Old Dec 23, 2006 | 01:45 AM
Reicherst02ws6's Avatar
Default 400 chevrolet sb?
My brother recently had a 400sb rebuilt and is planning on putting it in his 73 camaro. The other day we were priming the oil pump in order to lube up the engine and oil shot out of a tiny hole in the block next to where the distributor goes into the block. The hole is threaded as if something is suppose to go in it. Does anyone know what this hole is for? Thanks for all replies.
Old Dec 23, 2006 | 06:52 AM
02fastbird's Avatar
Talking
your kidding right..if not, its for the oil pressure sending unit...
Old Dec 23, 2006 | 10:20 AM
mrdragster1970's Avatar
6 & 8 Second Club
If I remember right it's 1/8th pipe for the oil pressure.
Don't worry about asking ??, nobody knows everything.
I learn stuff new everyday and I'm old. Good luck.
Old Dec 23, 2006 | 10:50 AM
N2O-ARMD's Avatar
It is 1/8 pipe thread if you buy a new oil pressure gauge it will have the fitting needed. or if your using the stock oil pressure gauge you need to buy a sending unit form the parts store or your local dealership.
good luck
Old Dec 24, 2006 | 01:30 AM
xdamxincx's Avatar
please use lots of jackstands when ur under a car...
Old Dec 24, 2006 | 08:44 AM
Strokinit383's Avatar
Yep oil pressure sending unit, it happens to everyone. After i built my motor i had an oil leak from a hole down between the fuel pump hook up and the timing cover.
Old Dec 24, 2006 | 11:58 AM
smokin2002's Avatar
Yep, just an oil passgae, lol, i pinched a microline for an oil prssure gauge back there one time under an intake, if you think just primeing it made a mess wait till motor is running hahahaha, If you have the sending unit mounted by the filter already just get an 1/8 pipe thread plug. about a .80 cent fix.
