easy 383?
If you use an old 400 crank there is some other mods, but you can get a new stroker crank made for a 350 block and it has the proper sized mains?? Haven't thought about it in many many years, so I'm sure someone will post up exact specs soon.
Do not grind on the rods for any reason. The rods do not need to be touched, there is no reason to. The block can be notched very easily to clear the stroke. Besides why weaken them and have to rebalance everything??
I've had to grind on rodbolts but that was it and even then I still didn't like it. Everything should be mocked up before balancing anyway.
The base circle of the cam can also play a roll as well as everything else thats already been said so it's always good to have all the components together before clearancing begins...
