Edelbrock RPM Air Gap Intake
One thing that has happened to me before is that the mechanical advance broke inside the dist. As it starts to spin it will go to full advance on you and give you too much timing too fast. If you disconnect the vacuum advance from the dist. you should have tension (light pressure to check) on the lever that the vacuum advance hooks into.
Originally Posted by 84MonteSS
how much taller is it than say, a performer rpm?
Did you get your low rpm stumble fixed?
