TBI to Carb
How much HP would it be worth to go from TBI to a decent carb and intake??
The 91 birds didn't have HEI distributers??
I'm going to try to figure out if they are the heads from a 91 305 or if they are from 79, the block is supposively from a 79 and its got some GM orange paint flaking off it.
What about the fuel pump though? Pressure just crazy high or something for the carb? I know carbs use way low fuel pressure compared to fuel injection.
just type in tbi to carb or whatever and you will get about a gazillion answers. Just dont post a new "Generic" question about it. That over there that is like asking "whats the difference between a camaro engine and a trans am engine" on here. They will get pissed and tell you to search. good luck
put in a normal HEI and wire its BATT wire to the large red coil wire from the TBI harness, white coil wire goes to TACH terminal on the HEI. ran my fuel supply line to a T, other 2 fittings off the T went to carb, and to an adjustable regulator IN port. OUT port of the regulator ran to the fuel return line.
simple conversion. not a fan of switching EFI to carbs but in my case it was necessary.
