Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Valve Spring Help!!!!
Old Apr 16, 2007 | 10:28 PM
My01SSCamaro's Avatar
Default Valve Spring Help!!!!
My brodix Ik200 heads came with Comp Cams 987 dual springs on it, My cam recomended the use of the comp cams 986 dual valve springs, the 987's have alittle more lbs so i thought i would be fine with this, My problem is i cant rev over 5500 it keeps floating the valves at that rpm and i dont know why the heads were already pre assembled when i got them but i dont know why it is doing this any help would be appreciated my cam is a hyd tappet Comp cam .507 intake .510 exh. 240 dur intake 246 exh dur, 110 lsa, with comp cam 1.6-1 fully roller rockers help please
Old Apr 17, 2007 | 07:49 AM
Shock Hawk's Avatar
You could get the recommended springs, but I would try something else. I'd call up Comp Cams and ask if some of their Beehive springs would work better. Beehive springs help to eliminate vibrations at high RPMs and, combined with light rockers, can increase overall hp, especially in your highest RPMs.
It's like this. A dyno graph of a normal engine goes down at the highest RPMs (due to vibration of the valve springs). A dyno graph of an engine with a lightened valve train goes up all the way to the redline. That means it pulls more hp up there. This can also help increase the RPM range (move red line up). I'll also help with throttle response since you have less mass (rockers), but not much, so don't expect the world.
Old Apr 17, 2007 | 09:26 AM
jmm98LS1's Avatar
Another vote for trying beehives (918's). I'm using them on my vortec headed 383.
Old Apr 18, 2007 | 05:57 PM
ive looked at the beehive's but i cant find one thats the right diameter my springs now are 1.430 od, if i go smaller do i need a spacer or something along those lines?
Old Apr 19, 2007 | 02:58 PM
Shock Hawk's Avatar
Just call up Comp Cams. I'm sure they have what you're looking for.
Old Apr 19, 2007 | 03:40 PM
jmm98LS1's Avatar
You'd just need the correct set of spring locators to center the beehives in your stock spring seats. They usually go for $40ish through summit, just find the ones that match the od of your current springs.
Check out this article, they did the same swap:
http://www.chevyhiperformance.com/te...e_spring_tech/
Old Apr 19, 2007 | 08:50 PM
ws6t3rror's Avatar
In order to run beehives on ik200 heads you will need the following.
26918-16 springs
795-16 retainers
4705-16 spring locators
614-16 10* locks +.050" installed height
ditch the factory shim under the 987's and you'll have to pull the blue valve seals off to get the locator installed onto the guide then just put a little oil on it and slip it back on. with the parts above you should end up with a 1.8" or so installed height.
it should also be noted that the +.050 valve locks will require you to run a rocker arm that is non self aligning
if all goes correctly it should look like this.
Old Apr 20, 2007 | 08:48 AM
Ryan02SS's Avatar
Going through something similar with my 355 SBC boat engine. I'm running Isky 6105 springs which are similar to your C987's, hyd roller 224/230 .537/.511 112LSA. I've been advised by a few engine builders to shim the spring pressure up to around 150 on the seat and 350 open to take care of the problem. However I am only going to be spinning 6K rpms max. If you are planning to go higher which I assume you are with that cam then you'll probably be better off with the 918 beehive conversion.
Old Apr 22, 2007 | 11:28 PM
26918-16 springs
795-16 retainers
Thanks for all the help i quess i need to call comp cams and see what they reccomend for me to do and what behive springs to get since im runnin a hyd flat tappet cam
Hey Ws6T3rror how do you like your ik 200's ? what kinda power you makin with em
Old Apr 23, 2007 | 01:47 PM
ws6t3rror's Avatar
if i was you i'd just run the 918's the pressure difference is about 15 psi on seat between them and the 915's and you'll actually get a good pressure over the nose with them with your lift vs the 915's.
as for how i like them i havent got the motor in the car yet (32 chevy roadster pro street). i'm still tweaking it on the dyno and gradually its becoming a very hard running piece.
360 sbc (.060 over 350) forged flat tops, gm steel crank, compstar rods, 4 bolt mains. ik200's beehives, super victor, 950 hp holley dp on the dyno, custom stainless headers built by me. custom cam i spec'ed 234/239 108lsa+1 .597/.605 lift 10.75 comp. so far after some tweaks and intake manifold work 522fwhp @ 6600 452fwtq @ 5200rpms.
Old Apr 23, 2007 | 05:52 PM
so if i get everything you listed above i souldnt have to shim the springs up? just wonderin that way i dont orded shims if i dont need em. thanks alot for the help, keep me posted on how you like your heads, im takin mine to the track once i get this whole problem figured out
