big block chevy cyl head castings
just curious i have a 1971 402ci what were all the heads used on these engines. The heads i have are casting number 3993820, are these heads anygood, i also have a set of 049 heads, i read were the 820s have a 113cc cobustion chamber that seems pretty small for a open chamber head. will these 820s work decent for a mild street car (71 nova) trying to get into the mid 12s.
thanks
Dustin
thanks
Dustin
They were used on the 300 and 330 HP 402s (LS-3 engine). They also may have been used on the 454. They have 2.19/1.88 valves and should be fine as long as you arent chucking it past 6k. I did read somewhere tho that you should have them CC'ed.
As for the 113 if it is going to be NA, then the higher compression ratio would probably help abit.
