Need input on particular needs out of a motor
Shortblocks are plentiful, so I was just wondering what would be a good starting point and build for the type of motor I'm looking for? Mild set-up, with a enough torque to leave off the line but have enough top-end to not fall on its face at 6k and be running 13.0's and 90MPH. A solid 350 with a healthy cam is kind of what I'm thinking, but I could find/go bigger for not much more. I figure for what I'm describing, a lot of it will be determined by the top end selection but I figure cubic inches might keep a more extreme top end more street-able, but anyway, any help and advice is appreciated. Thanks.
never had any clue on teh condition of teh motor ive seen soem at are local track go faster with zz4s may have done more work to them though
should exceed your expectations and still be in your budget
The car will see track duty, but will mostly be a cruiser. And I really want a car that can hang with its modded equivalent EFI car (2/3/4v Mustang, LS1 Camaro etc.) on the highway. It's always fun to be able to leave one of those from a stop light or a slow roll but i'd think it be more fun to be able to hold it off above 90, maybe even reverse the rolls and come flying past one of them once it gets moving.
It's hard to compare the top-end between the two motors, as my LS1 is moving a 3500lb aerodynamic body while the 383 is pushing a 4200lb brick on wheels
Based from your description, I think you'd be happy picking up that 400 block you mentioned and build a long rod 406 with some seasoned afr 195's, a decent roller cam and a rpm air gap intake. I think that could be done pretty easily for under $6k.
