Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
BBC on a 1985-3rd gen camaro ?
Old Jul 29, 2007 | 05:07 AM
35th SS's Avatar
Default BBC on a 1985-3rd gen camaro ?
was wondering if it would fit on the engine bay with no modification.looking down the road.it would be a slow build.thanks.
Old Jul 29, 2007 | 05:25 AM
BigB02Z28's Avatar
I had to do no modification to fit the motor. I had to do quite a bit of modification to fit the headers =].
On the passenger side, I had to hammer the firewall in about 1/2 inch at the very bottom. (Just to round it out a tad so the header wouldn't rub).
On the driver side, I had to put a little dent into the "frame" so the flange wouldn't rub.
All in all, it wasn't a hard swap. Myself and my buddy did it in the drive way with a few spot lights between 10pm and 6am... (We always work at odd hours).
BTW, this was a 1987 Trans Am, with a ZZ502 and the Hooker Long tube/Equal Length swap headers...
Post up any more questions if you wish. (I may be slow to respond since I am new to this forum and don't frequent as much as I want to).
Old Jul 29, 2007 | 10:20 AM
ZONES89RS's Avatar
In-Zane Moderator
Good to know! I will be running a 496 build for the street in a couple os years.
Old Jul 29, 2007 | 02:22 PM
G&HRacing's Avatar
8 second club
BBC in a 3rd gen is just about the easiest swap there is. With stock k-member just buy Moroso frame and motor mounts, done deal.
Old Jul 29, 2007 | 07:39 PM
JUICED96Z's Avatar
Yup! Thats about it. Everything else depends on what you run, some headers fit better then others.
Old Jul 30, 2007 | 01:43 AM
35th SS's Avatar
thanks guys.will put that in the back of my head.it is just my back up motor for now 496cid.have a 355cid sbc solid roller setup in there right now.thanks again.
Old Jul 30, 2007 | 04:43 AM
BigB02Z28's Avatar
My 502 fit fine, oil pan was a little close to the K member, but when I pulled it, there was no rubbing. I used the factory mounts. Car came w/ a 305, the mounts worked with my 350, and then to my 502.
(I was too poor to buy motor mounts! 18 years old at the time, and dumped all my money into a motor!)
3 years from then and I've learned.
Old Jul 30, 2007 | 09:28 AM
Street Lethal's Avatar
^ As already mentioned, a big block chevy into a 3rd generation is one of the easiest swaps there is. Heh, the BOP engines are getting much easier these days as well. Click Here .....
Old Jul 30, 2007 | 03:19 PM
radialracer's Avatar
http://www.edquay.com/
it's about the best place for the swap. the headers fit incredible for the price.
