9 second suspenion mods on a 69nova
Caltracs
Mon-leaf over the multi-leaf, less wrap-up, less stiff and they work better. All 3 of our cars have mono-leafs, the 2 nine second cars running stock replacement Eaton Detriot springs and I'm running Landrums, but if we ever need to replace them we'll go for Calvert's Split-monos. Used them on a 10 second Camaro and they work awesome.
a 28 x 10.5 x 15 slick will fit fine, but you'll need to roll the quarter panel out lip, as well as make a little clearance with the BFH mod to the inner wheelhouse. 15 x 8 rim with 5" backspacing if using a stock width rear-end.
Derek
I am debating mini tubbing it since the car is currently in primer. My problem is that I want to keep the 3" full exhaust and the fuel tank in the stock location (I like having a useable trunk). There just isn't much room left to move the shocks inboard and relocate the leafs. Do any of you guys have your Nova mini tubbed?
I am heading out to a street car heads up drag race tonight. I plan to run the radial class, but these little tires are kind of sketchy...
Derek
By the way, I raced in a radial tire class Friday night. The first two test passes I was blowing the tires badly when the nitrous kicked in at .4 seconds. I then increased tire pressure (M/T drag radials) from 14 psi to 20 psi, and delayed the nitrous to .8 seconds. That got my 60' down to 1.58 - 1.61 with 175 hp nitrous. I was able to qualify top of the 18 car field, and work my way down to the final round. I ran out of nitrous in the final. That will get you hooked on heads-up racing real quick.
I am not sure what the proper tire pressure for my combination is. Most everyone else was dropping their pressure in the radial tires, but it seemed to work better for me with higher pressure. Or it could have been the added delay in the nitrous timer.
Congrats on the final round showing, I agree heads-up or pro-tree racing can be addictive! Bring a spare bottle next time!
Derek
