Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Belt drive distributor??
Old 08-16-2007, 06:23 PM
redta24's Avatar
Default Belt drive distributor??
Hey guys my winter project is putting a carbed SB 408 in my 93 trans am.. the distributor has bothered me since I first thought about doing it and then i saw a pic of a guy with the distrubutor mounted on the front of the block and ran off a belt... Does anyone know where I can find this setup and get some more info on it? Thanks.
Old 08-16-2007, 09:14 PM
Strokinit383's Avatar
Its most likely a crank trigger setup. Not belt driven, but i can see how that would be mistaken. You would need these:
http://www.jegs.com/webapp/wcs/store...47909_-1_10679
http://www.jegs.com/webapp/wcs/store...47824_-1_10375
Old 08-16-2007, 09:45 PM
WE TODD DID's Avatar
None of those place the distributor in the front of the engine. That is impossible with a sbc unless you have a belt driven distributor. The crank trigger has nothing to do with that.
Old 08-16-2007, 09:51 PM
Here is what you were talking about. Jesel makes them.
http://www.dougherbert.com/frontdrivekit-p-10352.html
Old 08-16-2007, 11:38 PM
Super Speed's Avatar
Oh wow that price tag is HUGE!
Old 08-17-2007, 12:11 AM
Drumer919's Avatar
Its trickey to work on but you can fit a HEI disty up under the cowl.
Old 08-17-2007, 11:14 AM
redta24's Avatar
yea that price is crazy.. looks like i will have to try an hei with the crab cap. does anyone have good pics of a carbed motor in a 4th gen?
Old 08-17-2007, 01:08 PM
Now, you can use the low profile distributor and crank trigger as pictured in the first links posted, and that should fix your clearance problems. HEIs are good for regular stuff, but they tend to lose efficiency around 4500-5000rpm. I'd go with the low profile dist and crank trigger. The belt drive stuff is a little overkill for a street car.
Old 08-17-2007, 02:56 PM
redta24's Avatar
good info... Hell I spin the lt1 in there now to 6500 and the heads/cam setup for the new motor is good to 6500 so 5000 isnt going to cut it.
Old 08-17-2007, 03:05 PM
MrDude_1's Avatar
if you want a budget idea, the eDIST setups work great... its a simple wasted spark coil pack design... just run a crank trigger wheel up front and you're good.
Old 08-17-2007, 04:54 PM
I like the mallory unilites. They are very short and you can even buy a model with a crab cap. I had to replace the optical pickup inside mine and it took 5 minutes tops.
Old 08-17-2007, 10:39 PM
CNC BLOCKS N/E's Avatar
Here is a pic of the dist. we build for the blower engines we build as we use 44AMP mags on these engines and these are belt drives inside of the housing on the front. Just above the fuel pump.
Old 08-17-2007, 11:27 PM
91Z28's Avatar
It isn't too bad considering it includes a Jesel camshaft belt drive as well and they cost $852.00 alone.
Old 08-18-2007, 12:52 AM
In-Zane Moderator
ZONES89RS's Avatar
Man, after i get this LT1 running again, i might go to a gen I if it gives me **** again, the crank trigger sounds good.
Quick Reply: Belt drive distributor??
