Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
454 Heads on a 396?
Old Aug 20, 2007 | 09:30 PM
Koll's Avatar
Default 454 Heads on a 396?
As the title states. Could I run a set of 454 BBC heads (casting 343772) on a 396 block? Id like to find out before I get everything bolted down and find the valves hit the block.
Old Aug 21, 2007 | 12:49 AM
ZONES89RS's Avatar
In-Zane Moderator
Hmmmm....i am not too big on the knowledge side on the BBC like i am the mouse, but i think you can, someone here will be able to elaborate.
Old Aug 21, 2007 | 10:57 AM
Koll's Avatar
By the way.
343772.....68-86...oval...OPEN...366T, 427T, 454
Thats what the heads were for.
Old Aug 23, 2007 | 12:06 PM
1badnova496's Avatar
All big block heads will bolt up without problems with the valves hitting anything. I would advise against putting 71 and up 454 heads on a 396 since they have open combustion chambers unless you have a big dome like the factory 396/375hp piston.
Old Aug 23, 2007 | 12:29 PM
ZONES89RS's Avatar
In-Zane Moderator
Ok, i learned somthing.
Old Aug 25, 2007 | 10:22 AM
Koll's Avatar
Good deal 1bad.
The pistons that I have are some crazy big dome. I dont know the exact specs, but its large.
Old Aug 25, 2007 | 02:41 PM
edcmat-l1's Avatar
Depending on the cam, you may want to notch the block around the bores where the intake and exhaust valves come close. On the 396s theres a little notch there already.
The best way to view it is from the bottom of the bore. With the pistons out, bolt a head on, flip the motor over, and with checker springs installed, move the valves open and closed and see how close they come.
BTW, this is only critical when using 2.19/1.88 valves, like come in the factory square ports. Otherwise, with the smaller valves in the oval ports, its no big deal.
Old Aug 25, 2007 | 08:31 PM
whytryz28's Avatar
+1 for open chambered heads, and oval runners.
