sbc with lt1 intake and injection
^ Come on over to ThirdGen.org regarding welding in your own bungs, we're always discussing similar concepts in comparison w/the stock TPI, HSR, LT1 & Miniram conversions. Click Here....
Yea I would fab up my own deal to mount the TB to. I'm pretty sure that guy's dad fabbed his up for him. If you use your HEI what are you going to do with your computer and not having a crankshaft position sensor to calculate spark timing of your engine? Can you tune that out I wonder? Just something to think about. There is also another distributorless system that you could use in your application besides the one with LS1 coils if you can't get the HEI to work. http://www.delteq.com/index.htm Looks like a good deal for $700.
i dont have anywhere near $700 to spend. i plan on spending around 500 on this whole project. the very first tpi motor, 1985, used the hei distributor. the tach lead is what is plugged into the computer with some sort of filter on it. correct me if im wrong.
The distributor's themselves are pretty much the same (referring to the computer controlled versions from GM). What you'll also need to obtain is the pigtail from the engine harness, to the ignition module. The dizzy's themselves though are pretty common. Click Here, although this came from a TBI system, it's the very same unit found on the TPI's....
Originally Posted by Street Lethal
Tuned Port Injected engines didn't use a Crank Angle Sensor, as ESC (Electronic Spark Control) was controlled through the CC (computer controlled) HEI distributor. A used TPI dizzy can be found for very cheap, in fact, I have about three of them just lying around the garage....
Interesting! I have a 1975 camaro and I always like the idea of transplanting a LT1 in there with the pcm and harness! I'll be checking back here for info, thanks in advance for the info!
#33
Originally Posted by ZONES89RS
A TBI and TPI distributor are the same??? Or is the ign. cont. module just different???
#34
Well, that would be funny, i bet if they were people would sell used ones for more that used TBI dist....
#36
Originally Posted by fastcar65
are the new ls motors batch fire like the tpi's?
Also, for those curious about the older TBI to TPI swaps, click here....
