Turbo for a BBC
A full tilt Blow Thru Carb from CSU goes for roughly $1400 and is built to your engine and power adder combo. It is easily able to be dialed in for specifi A/F ratios and boost enrichment.
Its two diffrent ball games each with its advantages.
How finley can you tune/dial in your motor on one od those carbs compared to an XFI or something?
Went to the track Friday night and my AFR varied less than a point from start to finish. They're very tuneable.
Don't forget you can't run as much boost non-intercooled with EFI than you can with a carb. So on top of that EFI setup you need to add the cost of an intercooler. There are guys running 25+psi nonintercooled with a carb and C16 fuel. No way can you do that with EFI.
Craig
Craig
Im not a fan of not having an intercooler. Yeah I am sure you can get away with it but I am not a fan of not having one.
Cooler air = more HP.
It has to do with the transistion of the fuel via the carb. The air fuel atomization in the intake cools the air much like Meth. Where as the boosted air pressure inters the port and the injector is spraying the fuel. That is the lamens explanation with out getting real technical.
I have seen guys run 18lbs not intercooled on Blow Thru carb setups on the street during the dead heat of summer with no problems.
-Factory 454 Block bored .060 and machined
-Eagle 4.250 4340 Forged Steel Crankshaft
-Eagle 6.385 3-D 4340 Steel H Beam Connecting Rods
-8.6:1 Mahle High Performance Forged Aluminum Race Pistons
-Plasma Moly Performance Piston Ring Set
-Clevite 77 High Performance rod and main bearing set
-ProComp 320cc aluminum heads
-Decent BBC intake
-Nice Blow through Carb
-Nice solid Turbo setup with a 91mm
Comes out to a solid aluminum head 498ci BBC for well under $8000.
The engine could be built using a nice set of GM cast iron heads for $700 or so cheaper.
Point being that with a nice BBC you dont need huge boost to make more power than you will ever want on the street.
The combo above is running around on the street local here with 10lbs making well over 900rwhp. This is non-intercooled. It is in an early Nova. It is currently getting a large FMIC and Meth setup so that it can get turned up to 17lbs. The guy that owns the car built his own Carb using the instruction on TurboMustangs. He swears he has less than $10,000 in his entire engine and turbo setup.
My 468 with a BG 850 that flows over 1,000 gets like 7mpg mostly cruising around. Thats also with a TH-400, forged steel driveshaft and 12 bolt. At 60mph with a 28 inch tall tire its at like 2800 RPM.
I know a few guys that just about figure it in gallons to the mile not miles to the gallon on the cars.
As far as mileage is concerned with a BBC, I dont even think about it. I figure economy is a price you pay to have 1000rwhp and earth moving torque.
I think it costs me .75-$1.00 a mile when I go out, thats just cruising with half 94 octane half 110, no highway.
-Decent BBC intake
hmmm we need to talk lol..... Do you guys do bbc set ups? Im very interested in a combo just like the one you are talking about above.... Let me know.... Just give me a pm when you get a chance? thanks
The carb provides almost if not as much charge cooling as an air to air intercooler. I know several BBC combinations in the 496"-555" range, non-intercooled, that make anywhere from 1000hp to 1500hp. Mine makes somewhere between 1100 and 1200 on 16psi, non-intercooled, depending on the tuneup.
Craig
