Turbo for a BBC
All GOOD turbo setups are customs if you ask me.
Turbo size will depend on what boost level you want and what CUI you will have.
If you want it to run on 93 then you are fairly limited. Maybe a 76mm or something.
On the good forged bottom end and good heads....... it all depends on what power you want. You could go with some nice ported pro 1 heads or all out and go to the Big Chief level of heads.
First figure out what power level you want then go from there.
Now if you ask me one day in the next few years I want to build a 5XX aluminum BBC with twin T-88's ish, race gas.
I traded the 2000 Z28 Turbo shop car for a 72 Z28 roller. I am going to do a 496ci BBC with a single 91mm. I plan to keep it turned down to 15lbs of so. I wan to be able to drive it on the street some on pump gas. You dont need alot of boost on a BBC to make soem crazy power. I am doing a set of custom foward facing Turbo headers for my car. I am going to use a Blow Thru Carb also. I want something you dont see alot. No need for the big EFI systems. Its easy to make 1000+rwhp with a nice blow thru setup on a BBC.
A good budget turbo i could reccomend is a s400. They are mid $500 brand new. These are pretty large turbos and can support gobs of power. But like i said.. before you just go splurge you need to figure out a few things.
And blow thru with a carb is highly reccomend too. Setup right, blow throughs are badass. But if you have the cash for this, then obviously you have cash for EFI. Just remember, injectors and what not is NOT cheap. lol.
Carbs just like injected Speed Density setups require tunning in big weathers swings. Forced Inducted setups are tunned a little on the rich side for saftey sake and dont require much past seasonal changes once tunned in fully for WOT and cruise condition.
some examples of good carb'd turbo applications
When I get caught up at the shop bring me a 3rd GEN with a BBC between the fram rails and we will get a BBC setup knocked out.
My car is turning like 2800 RPM's at 60mph. But I think the gears in the tranny are not stock.....
One day I am going to go with a turbo BBC and but it in a 4th gen I think.
I personally wouldn't waste a bunch of money on EFI and an intercooler for your low power goals. Any 496 or 502, with a blow thru carb, nonintercooled should be able to make well in excess of 800hp no sweat.
Craig
Now if you want to go ***** to the wall then I say EFI or GOOD blow threw carb with a nice air to water innercooler (not a small under the hood one either).
I know a local guy that just built a 5XX BBC with wither twin T-76's or 88's sticking out of the hood, its pretty much ***** to the wall with power and a 25.1 cage.
Nice looking Firebird 1fastWS6.
Big stuff 3 alone is like 2k plus injectors and sensors ect ect.
Whats nice about injections is you can dial it in a lot better and per cylinder.
