Procharged Small Block?? Anyone
What's your CR? forged pistons? cam? fueling system? The answers to these questions will help us steer you in the right direction.
Crane Powermax Hydraulic Roller Cam
Grind Number: HR-230/359-2S-12.90 IG
Operating Range: 3000-6500 RPM
Duration Advertised: 292° Intake / 300° Exhaust
Duration @ .050'' Lift: 230° Intake / 238° Exhaust
Valve Lift w/1.5 Rockers: .539'' Intake / .558'' Exhaust
Lobe Separation Angle: 112°
Max Lift Angle: 107° ATDC Intake / 117° BTDC Exhaust
Open/Close @.050'' Cam Lift: Intake - 8° BTDC (opens) / 42° ABDC (closes)
Exhaust - 56° BBDC (opens) / 2° ATDC (closes)
any more tips?
Get the biggest (flow wise) blower you can afford. My recomendation would be at minimum a D1sc. F1 if the budget alows it. The more flow the blower produces the less hard you'll have to push it to get the power you want.
Make sure you take into account the ugraded fueling system you'll need. High volume pump at low working pressures is critical, as is a boost referenced fuel pressure regulator. Are you running the stock fuel tank?
Make certain that your return line to the tank is bigger than the feed line (8AN feed 10AN return seems to work well up to 1000hp, otherwise you'll have fuel pressure issues, get a quality carb hat too (extreme velocity, imo) and check out turbomustangs.com for the blow through carb basic modifications( drilling pvcr, fuel vent extensions, etc.) Ohterwise you seem good to go. That cam should work pretty well too. I see 10lbs of boost and 500whp in your future.
