Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Motor mounts
Old Oct 21, 2007 | 10:56 PM
1998TA__1991RS's Avatar
Default Motor mounts
Ive done alot of searching over the last few days and ive found mixed responses. Im starting a new project of putting a Carb'd 383 gen 1 into a 95 v6 firebird. So far ive found BMR and PA make K members. Im trying to do the whole project for under 3k total investment (already had the motor and got the car dirt cheap). I have a stock 98 ls1 k mamber laying around also. Ive heard of the appletree racing conversion mounts but i cant find them anywhere. Ive also looked into the madman motor plates but i want to save this as my last option. What would be the cheapest way to do this? how well would the LT1 mounts hold up with only 2 bolts holding them in? Thanks.
Old Oct 21, 2007 | 11:32 PM
ZONES89RS's Avatar
In-Zane Moderator
I am wanting to install a GEN I in my 95, allot of people i talked to said they had no problems with 2 bolts on each side. Dont plan on pulling the tires do you?
Old Oct 21, 2007 | 11:49 PM
ummmm...lol, its going to probably be either nitrous car or a turbo car. if i go turbo i wont be that worried about pulling the front tires
Old Oct 22, 2007 | 12:12 AM
TimTaylor75's Avatar
Get a motor plate from Madman. Will alleviate the header clearance issue at the same time.
Old Oct 22, 2007 | 12:20 AM
does anyone have any pictures with the motorplate installed? im interrested to see how it mounts to the frame, i also saw a motor plate kit that bolts to the frame, who makes that?
Old Oct 22, 2007 | 12:27 AM
From Madman's site
http://www.thunderracing.com/catalog...d=744&pcid=313
A couple more
https://ls1tech.com/forums/showthread.php?p=5503018
Old Oct 22, 2007 | 01:06 AM
would i also have to use a midplate with this setup?
are there any pics of motor plates with SBC's instead of ls1's
Old Oct 22, 2007 | 06:07 PM
stressfulcar's Avatar
Just a thought,but if he's going sbc,he should just be able to use a set of lt1 headers for the f-body if he would rather run mounts
I run a front plate on my bbc w/out a midplate,but I do have a limiter on it. Mine plates are madmans also,and they fit like a glove
Old Oct 22, 2007 | 06:19 PM
Drumer919's Avatar
I have a gen 1 motor in my 94 V6 car, I used a stock LT1 k member with LT1 mounts, I modded the driver side mount by adding material and drilling a hole but the passenger side mount I just used with 2 bolts.
Old Oct 22, 2007 | 08:24 PM
do you have any pictures of the engine in the car? Im trying to get an idea of how it will sit down in there. I hate to sound like a newbee but this is my first dealing with a Gen 1. i mostly stay with ls1's and ls2's
Old Oct 22, 2007 | 09:39 PM
Drumer919's Avatar
old
newer
I have better / newer pics but I dont have them hosted anywhere, hope these give you a general idea though.
Old Oct 25, 2007 | 07:50 PM
Hot Copper Z's Avatar
Here are a few of mine in the starting stages.
Attached Thumbnails Motor mounts-dscn0134-2.jpg   Motor mounts-dscn0135-2.jpg   Motor mounts-dscn0137-2.jpg
