Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Plans for the beast
Old Oct 24, 2007 | 05:40 PM
JUICED96Z's Avatar
Default Plans for the beast
Well the car is done for the year. Waiting for the title to come in (went to the DMV today) and also will have my plate come in in April.
I wanted RED ALRT or 1BADZ28 but they were both taken so I got
1SICKZ
Car is going to Burkhart Chassis around March or April we are thinking. Car will be legal to 8.50's and cut 1.2X-1.3 60's I am thinking (they said no problem to 1.3's on my 8.5 wide tire!)
Keeping the GM aluminum heads and having them and the Strip Dominator intake ported my a Pro Stock builder/porter. Having the BG carb sent back to BG to get re-blueprinted/built.
Going from a two stage to a single stage and hit the car out of the hole on like a 275 shot, electric water pump, better air filter set-up. If money allows I am going from the two Holley blue fuel pumps (seperate systems) to a single large pump and T-brake it before it goes back out. Dyno tune it at EPP also.
Based on what the car has run I am thinking it should run 8.8-8.9 on the bottle. We will see. If not at least BOTTOM 9's then something is wrong!
Not bad for a 468 BBC with GM aluminum heads.
Old Oct 24, 2007 | 09:53 PM
moge11's Avatar
Burkhart in Harristown?
Old Oct 27, 2007 | 02:49 AM
JUICED96Z's Avatar
The sponsors on here.
Old Oct 27, 2007 | 12:31 PM
moge11's Avatar
yeah, thats it. My buddy and I know most of the BIG drag racers in the area. We had to run out there for u-bend when fabbing headers for his Buick.
Where are u from? What tracks do u go to?
Old Oct 28, 2007 | 11:37 AM
JUICED96Z's Avatar
Indianapolis. Go to IRP untill I can geet my own truck and Trailer then I will start to go to some others.
Old Oct 28, 2007 | 12:29 PM
moge11's Avatar
Oh. Thats a long haul from INDY to Burkhart's. I live like 25 minutes from him.
Old Oct 29, 2007 | 03:31 AM
JUICED96Z's Avatar
A three hour drive is not what I call a long hall hahaha.
I think I am going to get the motor work done here pretty quick since I am not going to be able to get an opening over there for a while.
My buddy has an F-250 with an enclosed trailer and I think a winch in it so I might send the car to them engine/tranny less.
Old Oct 30, 2007 | 08:23 AM
moge11's Avatar
I just never realized how well-known Burkhart is. I guess they have an office in Decatur...probably a shop there too. I have only been to his house in Harristown....which is where I thought ALL of his work was done. I imagine he has another shop in Decatur.
Old Oct 30, 2007 | 02:01 PM
ZONES89RS's Avatar
In-Zane Moderator
U going to stroke it?
Old Oct 30, 2007 | 03:07 PM
moge11's Avatar
Yeah, STROKER! You ought to take it to +.100" and add the 4.25" crank=505ci.
DO IT!
Old Oct 30, 2007 | 05:43 PM
JUICED96Z's Avatar
If I stroke it and punch it I think these heads will be to small. Keeping it as is.
Old Oct 30, 2007 | 08:31 PM
moge11's Avatar
aaahhh....thats cool though. I think its cooler to "only have a 468ci" that SCREAMS vs. a 500+ci that runs OK anyway.....................But who cares what I think.
Old Oct 30, 2007 | 09:17 PM
ZONES89RS's Avatar
In-Zane Moderator
**** man, my end goal for my 89 is a 496 on the street, a supra killer ya know what i mean? I just am still having trouble figgureing a way to mount a T56 behind it.
Old Oct 30, 2007 | 09:22 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
LT1 style T56 are the ones I've heard work. I'm not sure about the bellhousing and quite a few companies make clutches for that application.
Old Oct 30, 2007 | 10:17 PM
ZONES89RS's Avatar
In-Zane Moderator
Well, the flywheel is my concern, i dont know which one will work yet. I did however find one to make my 408 i am building work.
Old Oct 31, 2007 | 11:18 AM
OWN3D BY MY PROF!
It's been covered in this section a lot. Just do a search for T56 in this section.
Old Oct 31, 2007 | 11:43 PM
JUICED96Z's Avatar
Fast cars with manuals don't mix.
Im helping a buddy build his Supra AGAIN, like a T-80 dual ball bearing turbo, everything ported and aftermarket intake, stage 3 cams, TH-400.
Going to have like 1,000 crank hp. On his last Turbo wich was a 72 I think and less port work on the heads it made more power sooner then any other Supra.
Him and I should be a good race.
People I have seen in f-bodies and stangs with other 500hp and sticks allways loose it seems from a dig. Every now and then they win.
Now if you only do roll racing then go for it.
Old Nov 1, 2007 | 12:55 AM
ZONES89RS's Avatar
In-Zane Moderator
I do whatever sounds good and i know my car is capable of. Wider tires allways help
Old Nov 1, 2007 | 04:34 PM
JUICED96Z's Avatar
I plan to run high 8's on an 8.5 wide tire
Old Nov 1, 2007 | 06:53 PM
OWN3D BY MY PROF!
Or you could also run considerably quicker on a larger tire. I get your point, but wider tires work.
