Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
I like to know ... stroker BBC
Old Nov 7, 2007 | 06:20 AM
almohands's Avatar
Default I like to know ... stroker BBC
hi guys ....
I like to know the proximal Wight for BBC 496 engine assembly
This Complete Kit Contains:
Scat Series 9000 Pro Comp Lightweight Cast Crankshaft, 4.25" Stroke, 454 main, 2 piece Rear Main Seal. Kit is designed to internal balance (Will need to be balanced before assembly, may require heavy metal to balance.) This crank is approximately 67 lbs. PN: 9-454-4250-6385
Scat Premium 4340 Forged 6.385" I-beam Connecting Rods with ARP 7/16" 8740 Capscrew Fastners, Floating Pin, 2-ICR-6385-7/16
JE SRP Forged Pistons, PN: 212157, 4.310 bore - These pistons are +.060 bore (Other sizes available, please inquire) estimated compression is 10.2:1 w/ 118cc heads
Perfect Circle or Total Seal Plasma Moly Rings
Clevite 77 Performance 'P' 454 Main Bearings
Clevite 77 Performance 'P' 454 Rod Bearings
i hope to help me
Old Nov 7, 2007 | 11:03 AM
ZONES89RS's Avatar
In-Zane Moderator
I herd a BBC with aluminum heads weighs as much as a full cast irn SBC. I really wonder if that true?
Old Nov 7, 2007 | 01:48 PM
almohands's Avatar
Impossible
the BBC block weighs much SBC short block
Old Nov 7, 2007 | 02:55 PM
BMC_Punisher's Avatar
Originally Posted by almohands
hi guys ....
i hope to help me
With a cast iron intake and cast iron head around 685 lbs. Small blocks are around 550 lbs. These are complete motors stock. Cast iron everthing.
Old Nov 7, 2007 | 11:54 PM
ZONES89RS's Avatar
In-Zane Moderator
So maybe 600 with aluminum heads?
Old Nov 8, 2007 | 12:44 AM
I would say you will drop 70 lbs just with aluminum heads and 20 or so lbs with an aluminum intake so right under 600 like 580 or so.
Old Nov 8, 2007 | 01:12 AM
ZONES89RS's Avatar
In-Zane Moderator
So pretty damn close to full iron SBC weight, that is cool.
Old Nov 8, 2007 | 02:11 AM
Yeah pretty close. I mean as close as your gonna get with a dam boat anchor. BBC stuff is unbelievebly heavy so to drop that much weight switching heads and a intake is pretty good. Make a big difference for the car .
Old Nov 8, 2007 | 04:17 AM
ZONES89RS's Avatar
In-Zane Moderator
Hell yea, i am going to be a 496 on the street in my third gen, i was not wanting to have to swap springs and what not.
Old Nov 8, 2007 | 08:03 AM
almohands's Avatar
Thank you guys ....
and how much weight for stroker kit only ?!
the piston and rods maybe around 33 - 45 lbs
the cast crank 4.25 ?!!
Old Nov 8, 2007 | 11:07 AM
ZONES89RS's Avatar
In-Zane Moderator
Eagle sells a 496 hit for 2200$, i have seen a 489 kit from scat for 1750$. I am going to use the scat kit when it is time for me.
Old Nov 8, 2007 | 02:35 PM
almohands's Avatar
thes scat kit 1200$ only for 496CID
but i what to know the weight for stroker
Old Nov 9, 2007 | 12:54 AM
ZONES89RS's Avatar
In-Zane Moderator
1200 is not for the forged kit.
Old Nov 9, 2007 | 06:10 AM
almohands's Avatar
forged kit but the crank cast iron
the forged kit rang 2000 to 3000 $
Old Nov 9, 2007 | 11:19 AM
ZONES89RS's Avatar
In-Zane Moderator
Well the jegs catalog in front of me is 1750$ for the forged kit.
Old Nov 9, 2007 | 02:53 PM
whytryz28's Avatar
I have small block springs that i can use with a big block w/ aluminum heads, so the weight is similar almost.
Old Nov 9, 2007 | 04:11 PM
almohands's Avatar
nice man
i Thinking to put the 496 CID with 14:1 CR and aluminum heads
on camaro gen 3rd
Old Nov 9, 2007 | 04:15 PM
almohands's Avatar
nice idea
but the style Difference ?!
