De-stroked 377 (400 block w/ 350 bottom)
Thats kinda what I was thinking, but I already have some of the stuff to do a 377. So I will do the 406... I've looked and decided to get the following: Eagle Street/Strip bottom end (Cast crank, H rods, Keith Black forged pistons) Partiot Freedom series heads w/ custom cam (240-260 and ~ 525-530 lift, havnt decided yet) Vic jr intake and holly 750 dominator. I'm thinking about 475 w/ this set up w/ no spray.
Don't over build the motor. For what you're wanting you can run lighter parts like I beams instead of H-beams and it will be cheaper and make more power. Also depending on how much N2O you want to run, you can use hyper pistons instead of forged.....lighter and cheaper. You can use the money you save on the short block to put money into the heads/valvetrain cause that's where you make a lot of power.
Definitely. And DO NOT use a DOMINATOR!....OVERKILL. Get a 950HP series carb...It will be all the carb that motor will ever need and be WAY MORE STREETABLE, and get WAY BETTER mileage. The heads are a good choice the crank and pistons are good choices, but definitely need to go with I-beams over the H-beams.
This a general guideline on how to size a carb for your motor.
http://www.classictruckshop.com/garage/shopmathcfm1.php
6 & 8 Second Club
2 thoughts, I have never seen anyone run a 750 4500 & like it. I was told by several guys it is the worse holly ever made. Circuits just do not work well on something they choked down so small.
I also do not think a 950 hp is going to work well with a engine so mild. Good luck.
I am also wondering if this carb that the origional poster has is really a 4500 series Dominator or if it is just a 750 DP 4150 series. I agree a good 4150 series 750 cfm carb would work the best in this situation.
Its not the 4150... I was thinking of going w/ the 4500... I like the style and it does get a bit better gas mileage. Been there, done that. I had one on a 355 and it did GREAT!! I never had any problems w/ the tuning falling flat or hell, anything for that matter.
