632 BBC input
I have always wanted a blower motor. Found a BDS 8-71 with tall deck manifold. What would be a good cam to go with for decent drivablility? I'm not wanting an all-out race engine that I can't drive around the lake.
But I've been tossing around the idea of a N/A n2o motor as well, maybe 10 or 10.5:1 CR with up to a 400 shot. Any suggestions for either build-up?
Why do you need a 632" if you want a mild crusier. Plus a 8-71 might not be the right size. A small blower like that on a 509" would be a ton of power. Blower motor will be more reliable & consistant than something with a big shot like you mentioned. Even a 540" would be a handful. Any stock angle, aftermarket heads will work good, I would probably go by what the best deal you can find. Just my 2 cents.
Make sure you get some expert help with that combination. Like I mentioned, that blower is very small for a 632". I have many friends with blowers & anything over 500" have a 12 or 14-71. If you're trying to hang with some big dogs, you have to bring the right stick to the fight. Just trying to help, injected or dual dominators at a minimum for a 632" blown motor. I would hate to see you get into something & waste a ton of money doing stuff twice. Check out Jim Oddy, he is a blower motor genius. Fowler is also big time expert on blower motors. You will learn alot more from them, then us yahoo's on a web site. Good luck.
Why not a turbo motor and keep it on low boost until you want to play? LOTS of big power turbo motors with lots of manners on low boost. Has a cool factor also.
A while back we were talking about a TT 454, figured with the cold lake water we could run more boost. My buddy building a TT 383 3rd Gen. said we could get an easy 1500hp that way. Would have to use some 160# injectors and maybe a water/meth injection at times.
Something similar to this, but with the turbo centered over the valve covers and the inlets forward/outlets rearward and clocking the turbos to where the charged air is aimed directly into the TBs instead of all the piping used in this setup
Well that's different. Now that we know your budget, you're pretty much screwed.
I seriously doubt you can do a turbo or blower 632" for that.
The N/A 557" BBC for my slow car cost more than that.
If you could do it for that, I wouldn't stand near it when you hit it.
Good luck, I hope it works out for you.
Found a couple of prices for mild street blower engines, hope it helps.
Street/Bracket 383 Cu. In.
Small Block Chevy Blown –
700+ H.P. On Pump Gas
Starting at $14,900
Street/Bracket 540 Cu. In.
Big Block Chevy Blown – Gasoline
1000+ H.P. On Pump Gas
Starting at $24,900
Street/Bracket 460 Cu. In.
Gasoline Big Block Chevy Blown – Gasoline
800+ H.P. On Pump Gas
Starting at $19,900
Bracket/Quick Series 540 Cu. In.
Big Block Chevy Blown – Alcohol
1400+ H.P. On Alcohol Big Power and Torque
Starting at $29,900
short block: 6500
oil pan and pickup:250-300
oil pump: 100bucks
custom cam from straub technologies: 400
pushrods/roller lifters/rockers :600
gaskets/studs: another 300
14-71 blower: 5000
dominators: 1200
fuel lines/linkage/scoop:450
ignition system:650-700 with boost control timing
good race fuel pump:200
headers:800-900
Yea a little more than $15k. $19,150 for a blown 632. For under $15K I can lose the blower and go N/A and spend around $1k on nitrous. But if I'm going the blower route I'm sticking around 500". That way I can run a 10-71.
