Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
How rough is this cam?
Old Jan 1, 2008 | 06:06 PM
F-Body Lover's Avatar
Default How rough is this cam?
I got a Lunati Solid flat 245/255 @.050 532"/552" 106LSA I know its a rough cam but how rough it is? it will be in a 355 with sportsman II heads,victor jr intake,750 chokeless carb,LTs,pulleys,,,,etc but does anyone have a video of the same rough idle this cam got? I tried in you tube and the roughest cam I found was 112LSA
Old Jan 1, 2008 | 09:06 PM
ZONES89RS's Avatar
In-Zane Moderator
Yea, VERRY rough. On a 1-10 scale, a 8.5 or so.
Old Jan 2, 2008 | 06:30 AM
Nate81Camaro's Avatar
Your car will go "rump.....rump....rump".
What's the rest of your combo? (compression and what stall are you going to use, etc)?
Old Jan 2, 2008 | 09:20 AM
the compression will be around 10-10.5 and I will put Fuddle converter 3500stall,3.73 and my camaro already got posi,255/50/16 M/T but Im thinking of Centerline convos 15×4 front and 15×10 on the back but I cant find the perfect back space so I will leave it for later,Eibach sportline kit,KYB AGX,the tranny is 700 R4 with shift kit and clutchs so all I need is gear cooler from B&M,B&M pro ratchet shifter,Long tube hooker super competition custom Y pipe and already it got Magna flow cat back thats all I can remember for now
so with this cam I will lose the brakes right? and I need the vacuum reservoir,all this for a 92 Camaro Z28 25th anniversary
Old Jan 2, 2008 | 05:47 PM
1994Z28Lt1's Avatar
im no cam expert but with a compression ratio of 10-10.5 will be a little low for a cam with that much overlap
Old Jan 2, 2008 | 05:48 PM
Shawn @ VA Speed's Avatar
That cam is way too big for that engine combonation.You will have to run it to 8000rpms to get any power out of it.What is your end goal from this engine/car?
Old Jan 2, 2008 | 07:56 PM
1994Z28Lt1 I was thinking of something like 12.5:1 C.R thats more like it
Shawn @ VA Speed well I got this cam for free and the sportman II heads for free the short block is from my brothers C4 86 new speed pro pistons for free so I just want to have fun and kill fast cars so you tell me the best set up for this cam and those heads
Old Jan 2, 2008 | 08:39 PM
Run this cam,Comp Cams 12-433-8,its a hydraulic roller.I run this cam in the 450hp 350 street engine i build.Cam makes great power from 2700rpm to 6200rpm,excellent street cam that makes lots of power.will work great with that 3500 converter and 3.73 gears.Oh yeah,it sounds really nice too.
Old Jan 3, 2008 | 01:53 AM
streetassasin's Avatar
holy hell that cam is a monster
with the wheels I ran a 15x10 prostar with a 275/60/15 tire with 5.5bs on my old 89 RS and it was a perfect fit lmk if you want pics
Old Jan 3, 2008 | 06:56 AM
but my camaro got the 4 wheel disk option I tried my friend 15×10 they were for his drag car but with more than 5.5 backspace they didnt clear the caliper after while I tried another convo's but the weird thing they were not 15×10 they were 15×9.5 with 4.5bs I was like what the hell? I checked jegs and I didnt find 15×9.5,I will appreciat some pictures of your camaro
Old Jan 3, 2008 | 10:41 AM
here you go man
Old Jan 3, 2008 | 10:46 AM
ZONES89RS's Avatar
In-Zane Moderator
My convo pros are 15x8.5, is that maybe what you had? I think you might be able to gtind your rear calipers like a LT1/LS1 do i am sure.
Old Jan 3, 2008 | 11:53 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Swap cams, that puppy is way big and you'll likely have more fun with something smaller. Keep in mind that you may have to run race gas (or at least a mix w/93 pump) with a 11-12.5:1 compression ratio and iron heads. Aim a bit lower 10:1 or less and you'll be safer.
Derek
Old Jan 3, 2008 | 07:17 PM
well I got a 383 complete engine without headers and pulleys sitting in the garage it has air gap performer rpm,sportsman II,750cfm vacuum,lunati hydraulic flat(dont know the numbers),1.6 rockers the blue ones and the connecting rod is 5.7 but I dont know from which company the stroker is and I dont know the compression ratio so I will wait 2 months and I will see later but thnx anyways for helping me out
streetassasin DAMN thats all I can say
Old Jan 4, 2008 | 06:17 AM
ATCFLYBOY02's Avatar
Man... if you run that cam, you'll feel your peanuts giggle in ur draws when your at 70 MPH... hehe
Old Jan 4, 2008 | 10:32 AM
thanks man I sold her a few months ago
Old Jan 5, 2008 | 12:23 AM
a-mean-89-iroc's Avatar
lol yea that cam is an animal! One of my friends is runnin a cam similar to that except the lsa is different! And he has a built 496!
Old Jan 6, 2008 | 08:08 AM
Russ432's Avatar
That is a circle track type grind. It will have a nasty idle, but be very streetable as long as you run at least a 3500 converter. The 106 center gives it good low end power and in a 350 will pull good from 3500 to around 7200 and sound good. I ran that cam in my work truck that had a 406 and 10 to 1 compression. I drove it thru the winter and back and forth from michigan to mass it always ran great.
Old Jan 6, 2008 | 11:34 AM
thats good news to me I think I will keep the cam because I was thinking of selling it,do you have a video of your truck?
Old Jan 6, 2008 | 11:52 AM
What do you consider good low end power-how about some dyno numbers
And a 350 requires a totally different cam than a 406.
