383 or 400
its going in a 2580 lbs 73 240z (the weight is with the 350) the car is a street car on pump gas and would like to keep it that way.
thank for your time.
Certainly use the 350 block you already have, but don't be afraid of a 400. My first 406 had stock cast crank (.030/.030) with 5.565" rods and forged pistons. It held up just fine to nitrous.
thanks for all yall input. my goals are pretty simple, wanting to step up the motor and keep it on pump gas and be able to drive the car where and when ever i want.
right now its just a 96 vortec motor with a gm hotcam some spray. the car has been 6.14 @112 in the 1/8 on the 250 shot, which was driven to the track.
i have heard people saying to do both with both 383/400 to 406 but was looking for some more input.
Reliability is a washup. The 383 has a better track record but there are far more of them out there. Built right, both should prove very reliable.
As to performance the 406 will always outpower the 383 apples to apples. It has 23 more ci,a much larger 4.155" bore vs 4.030" which aids in unshrouding the valves and allowing for better flow and more power. Built with longer 5.7-6" rods they are much more rev friendly vs the 383 due to their bore/stroke ratio and rod ratio.
Either way you go should provide a decent power increase with that light car.
sick240, that's moving! Congrats.
It was also a block that had never been bored out. Eagle is making 4340 forged steel internal balance cranks for them now, so that is what I bought for mine. Whenever you see any good 400 blocks for a decent price you better buy them up. The supply is dwindling down pretty fast.
