Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
A Few Progress Pictures
Old Feb 19, 2008 | 12:27 AM
Websy21's Avatar
Very clean install, like the sheetmetal work. Are you planning on racing this is or is it a street car
Old Feb 20, 2008 | 10:36 AM
Sandmann120's Avatar
Very clean. Any chance you can get some shots of how your carb fits in relation to your windshield?
Old Feb 20, 2008 | 01:25 PM
mrdragster1970's Avatar
6 & 8 Second Club
You must have the patience of a monk. I want to go fast & I want to do it NOW.
Excellent work, good luck finishing.
Old May 13, 2008 | 04:49 PM
98 Silver Bullet's Avatar
A few more pictures. Finished the brake lines and installed a Madman torque arm. It sucked because I already had the carpert installed & have you to notch the trans. tunnel when installing the crossmember. At this point I'm waiting on the hood and in the process of wiring the car. All the engine & transmission wiring is done and pulled in to car. Still have to wire the fuel pump relays which will be in the back, install the dash, & wire up gauges, fuse blocks, & switches.
Attached Thumbnails A Few Progress Pictures-car-025.jpg   A Few Progress Pictures-car-026.jpg   A Few Progress Pictures-car-024.jpg
Old May 13, 2008 | 07:25 PM
6 & 8 Second Club
Excellent relay set up.
Old May 14, 2008 | 03:43 PM
87Lt1Monte's Avatar
That is AWSOME man...
Old May 14, 2008 | 04:08 PM
RAGENZ28's Avatar
Nice stuff, can you take a side profile of the motor and if possible tell me how far the carb is from the window. I am doing a BBC also in my Camaro.
Old May 15, 2008 | 11:01 AM
If you look closely, I notched the cowl. I'm using a lexan windshield which will have to be installed with a notch as well. 2 reasons, the rear float bowl touched and it was about 1/4" from the windshield. Any movement of the engine would probably crack the factory glass. There is about 1/2" of front to back adjustment in the transmission mount. If you take this in to account when you weld in the motor plate mounts, you can move the engine forward more. I did not...and, the motor plate mounts are welded in. The second reason, unless you use a front mounted distributor, It appeared to me at the time that you can't install it without removing the engine (At least the distributor I’m using). I didn't test this theory. I just wanted easy access to the distributor for installing & priming the oil pump purposes.
