Main and Rod bearing question
What is your budget? How much HP? How much rpm do you plan on turning? That cast steel crank is stronger than what most people will give it credit for. I've seen them live at 600-620 HP turning 7200 rpm regularly in the alcohol modified's around here. Make sure that you buy some good rods, as that is where I see most of the failures in these motors.
If you go with King use their Alecular HP series. The ACL H-series bearings are good. The Clevite H-series have been used for years without problems. Just make sure to get a H-series as the back of the bearings are stiffer and less likely to distort & spin. I prefer the coated H bearings myself.
