sepentine or v-belt?
Which one should I use on my new engine? I have all the parts for both.
I like the less cluttered look of v-belt but Ive never used them before. The serpentine is the one I used before the engine blew but its heavy and still has the a/c comp. on it(no$ for delete pulley)
So which one should I go with?
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
What kind of serp. brackets do you have, I dont think a TPI f-bodt setup would look to bad but the ones I used were the TBI truck brackets and it was a huge bitch.
Just out of curisoty how much do AC delete pulley's sell for? I have one but the damn bolt that holds it to the bracket is seized in the bracket, I always wondered if it would be worth the time to try to get the bolt out and sell it.
I guess since my new set up wont be all that powerfull I could try out the v-belt, worst case I can always swap it out for the old serp.
Hey, drumer, u have any pics of your engine bay? what kind of power you getting with that cam?
I've always used the late 80's f body type, it's more of a multi ribbed flat belt that follows the same path as the old v belt. As in just around the crank, water pump, and alt. I originally used this to prevent v belts from flying off.
Later I just realized it looks better.
I don't call it a serpentine set up because the belt is short and nothing rides on the smooth side of it.
