Thumpr Retro-fit cams
I think everybody saw the retro-fit cams that Comp cams offers but I was thinking of putting a retro-fit hydraulic roller in a roller engine instead of hydraulic flat,will it work? I mean those cams were made to fit a roller cam in hydraulic flat engine but will it work fine if I fit the same cam in a roller engine? I found this note in Summit (Notes: Designed for engines originally equipped with flat tappet camshaft.) so does any one did this before?
I will get timing gear for super charge noise ,so 85 and earlier timing chain is a must and cam button and use the OEM roller lifters thats all?
