help again. burnt pistons
In-Zane Moderator
ALLRIGHT, not trying to hijack this thread but what about the FORGED kieth blacks??? I just got them for my build, it is a totally different ball field than the hypers right? I dont want this thing letting go any time soon, atleast i know i have 93 octane and it is only 11 to 1.
The KB forged pistons are made of a 2618 alloy the same as JE, Ross, Weisco, & Probe. Now then, there are different sources of the bar stock used while making the forgings, but you should be easily able to handle 800+ HP. The Hyper's get a bad rap due too running to loose of piston to cylinder wall clearances b/c they think that .0015"-.002" is to tight.
#33
LS1Tech Sponsor
I apologize for not reading all the responses, but that damage is apparently due to insufficient end gap on the rings.
If your engine is naturally aspirated the pistons aren't as critical (forged isn't required). But checking end gap on the rings is imperative on any custom engine. All high-end rings provide recommended gap in the instructions and I've never been steered wrong following the instructions.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
#34
In-Zane Moderator
Sweet, i am running a scat 9000 cast crank but i think itl be fine. The rods are scat I beams for 700 HP.
What do you guys think about the 40$ chromolly speed pro rings? Think they'll be fine? I was going to buy them and gap them acording. I have read the directions from KB that came in the box but are the speed pro rings setup to be gapped? I might even go with the plasma molly speed pros rings since they are double the price and everyone else seems to use plasma, any input for that?
#36
That's exactly what I'm using with the KB's in my engine. They've been fine so far (even survived 30 minute sessions on the road course at Nashville Superspeedway).
#40
in that rpm range the advance springs really shouldnt matter for your power band, it will be fully advanced befor 4000 with any typical springs, i would put the heaviest spring in to bring on timing slower to help with the detonation problem. just curious how much timing did you have in it befor........
