350 Tpi
Trick Flow 195 heads, ported
Lunati 226/232 camshaft, .580" lift with 1.65 rockers
Specially ported Edelbrock TPI intake, flows 300+ cfm
Specially ported SLP siamesed runners
TPIS 52mm throttle body
Dyno Don 1 3/4" shorty headers
2 1/2" custom dual-cat y-pipe
Custom 3.5" exhaust with Magnaflow muffler
Custom prom programming by me
T56 transmission
You can substitute your own camshaft in that range, but the custom prom tuning is a must. You can also try the StealthRam if your state doesnt do smog checks, but keep it mind that intake deletes the EGR. The new AFR Elminator 195 heads are great, too.
I posted my dyno graph in this thread:
https://ls1tech.com/forums/small-block-big-block-chevy-specific/903103-cam-package-my-friend-s-tpi.html
My dyno numbers are new, but the ET is four years old from my old combo.
Good luck with your build Ahizzy, hope you get the numbers you want.
it is really hard to beat "MODERN TECHNOLOGY" and that is what the Ls series has above all other engine combinations.
i love 3rd gens the body lines are absolutely sexy,too bad mine got hit
NO OTHER F-BODY can corner the way a 3rd gen can then add the power and Ls base engine can provide along with the power to weight ratio the 3rd gen turns into what i would classify as a supercar..........
Now, the LT1....i curse it till my grave
