BBC in 4th gen
Explain how higher RPM's make it less streetable? With your tall of a tire you will not need a killer gear and you don't have to have a killer stall for high RPM's.
As far as stall I really don't want to go over 4,000 tops. Cam I was looking at is 279/289@.050 .748/.748 on a 114 lobe.
It will make around 900hp in a 750 set up right
I would not say those Edelbrocks are the top dogs in conventional stuff either. A few that are better but you pay for it, thats a matter of opinion though.
P.S. Generally you pick your stall based on what the cam wants.
Another one was 284/292 .748.748 on a 112.
Both made peak power around 6,500 and peak torque around 5,500. As far as the research I did from conventional heads, the Edelbrocks with that cc and price range make more power than comparable heads.
As far as stall, I am not going to put something for optimum drag running, it's a spray motor it'll kick *** with 3,500 or 4k max stall.
Not saying to stall the crap out of it, just saying cams need matching stalls.
From what I can tell mine is a 3800 stall on motor and goes to near 4000 or so on the bottle (also based on info from Coan).
My old cam makes peak power at 7k so I would do some research before you buy or decide.
It's not like a small block, even at 3,500 it's going to be over 700 ft torque.
Looks like those heads are pretty good, I was thinking of plain ol Edelbrock.... my bad.
If I go the troute I am thinking with the Notch Ill get I bet it will be Canted heads.......
Im sure it would not be very fun on the street but Ill have a fun street car, the mustang will be a 90% track car.
I'm building my motor to run on nitrous, I don't care what it runs on the motor, I'll only be cruising it on the street so if it went 12.50's on the motor and 8.50's on the bottle I wouldn't care. 3,500 stall and I am leaning towards a 2.10 1st gear TH400. I'll have a pretty big tire so I can get away with a little more trans gear I think, besides a power glide on the street would suck.
I'm probably going to get something around 270/284 .714/.714 on a 114, I don't think it'll make 900 hp but even if it made 800 or 825 or 850, it doesn't matter. I may go even smaller. I should need under 900 hp to go 8's, and I'll have my fogger so even with a super mild 598 that made only 700 hp, I'd only have to spray like 150-200 hp to run my goal et. 150-200 shot on a 598 isn't ****.
Those are some heads I have been looking at. I know most of the poeple that use them are N/A guys and stuff gets $$$ when you go big chief.
Those are $5,400 plus tax plus shipping BARE.
Get a valve train and inconell exhaust valves, titanium intake valves (both are pretty much a must for high boost) ect ect and I bet you are over $8,000 easy.
Not something I will just looking around for a few minutes then hand over the mastercard HAHAHA.
Not to mention an intake!!!!!!!!! Something tells me a cast intake would choke those heads out.
To think I could buy a nice crate motor for the cost of the heads hahaha
Do some more checking before buying a small angle profiler. 18* would be a better combination head. N2O seems to like more angle.
No expert, so do more checking on the latest & greatest thoughts of the experts.
Another thought, if you're only looking for 8's you don't need as much engine as you are planning.
At 3200 lbs with a 454 block, chevy crank, old *** heads & 150 shot I ran 8.50. Crap 60' on 10" tire.
Build your 632", make it as strong & streetable as you can afford. Throw a fogger on it & your done.
Conventional head, mild compression. Don't forget, the bigger the engine, the less stress & strain the N2O causes.
A 400 shot on a 632" is mild. A 400 shot on a 350" is killer. Just a thought.
What does this car weigh? You might be closer to 7.99 than you think. Good luck.
I want to use a longer rod for street use, but also have enough room for a good nitrous piston, 632 has too much stroke to do that.
Main factor will be using a cam that can be mild enough for pro street use, then using the nitrous to make up the difference. I honestly think I can make 800 hp on pump gas with a moderate size roller cam.
Either way I'll get it figured out, there are a few guys helping me select the right stuff to meet my goals.
I don't know what the car weighs, but other guys with similar BBC tall deck stuff with full body and floors are around 2900-3000. Mine has the entire floor removed, most of the shock towers, everything in front of it, plus it's lightened up a few other places. I think I can maybe get it under 3,000 race ready, I'm 200 pounds so I am shooting for 2,800.
That should only take 800 - 825 hp or so to break 8's, If I make 800 on motor and spray 300-400 that's 1100-1200 hp
should make it well into the 8's especially with a 4 link and 32/33" tall ,15/16" wide tires. I'd think it could go 8.20's and 5.20's in the 1/8th. Last edited by RAGENZ28; May 22, 2008 at 01:56 PM.
We need more PICS
