Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
383 with 5.7 rods
Old Jun 27, 2008 | 01:48 PM
1fastirocz's Avatar
Default 383 with 5.7 rods
Can 5.7 rods be used in a 383?
Old Jun 27, 2008 | 03:10 PM
1989GTA's Avatar
Sure if you already have them and the pistons to go with them. If you are looking to purchase then I would go with the 6" rod as the price is the same.
Old Jun 27, 2008 | 03:30 PM
ZONES89RS's Avatar
In-Zane Moderator
You can use the stock 400 rods, 5.7 rods and 6.0 rods. Just have to have the correct piston pin location.
Old Jun 27, 2008 | 04:50 PM
1fastirocz's Avatar
I already have the rods they are Eagle 4340 H beam 5.7 large journal. I was planing on using the forged pistons that are in my 355 right now and replace the rings if they look good when I take the motor apart and buying a compstar or eagle 4340 forged steal crank. What stroke crank will I need for the 383. I know it is a 400 crank and the block will have to be cut for the bigger crank. My block is a one piece rear main seal and is already bored 30 over.
kenSS's Avatar
if you are buying new, then i would go 6"
Old Jun 27, 2008 | 04:52 PM
1fastirocz's Avatar
What are the advantages of using the 6'' rods ?
Old Jun 27, 2008 | 04:59 PM
kenSS's Avatar
For one, a lighter piston, for two, less wear on the cylinder walls. quicker revs.
Old Jun 27, 2008 | 07:49 PM
ZONES89RS's Avatar
In-Zane Moderator
The forged pustons in your current block you have would require the use of a stock size 400 rod. Otherwise, the piston will come out of the block about .200 or more.
You have the crank resized if it is a 2 piece block, you have a 1 piece so you need a aftermarket 3.75 stroke crank for you application. Not to mention you need stroker pistons for the 5.7 rod.
Ebay sells a set for 330$ i believe from Kieth black, that is the forged model. Verry light but uses the regular rings, not the thinner low tension set.
Old Jun 27, 2008 | 11:30 PM
1fastirocz's Avatar
I think I am just going to rebuild the 355 with a forged 4340 compstar crank, eagle h bean 5.7 rods, clevite 77 bearings, the Trick Flow heads that are on it now, all arp bolts and studs, and put Je nitrous piston rings and a TPiS mini ram intake and a 150 or 200 shot of nitrous and run the hell out of it then get my car painted. I really want to get it back to together by January so I can ride it to school. Then I am going to start building a twin turbo 406. Does anyone know what it might run in the 1/4 mile with the forged 355, TPiS mini ram intake, Trick Flow heads and a 200 shot with slicks? It ran 11.62 with the 355 Trick Flow heads, Accel lower intake, runners, 58mm throttle body and a 125 shot.
Old Jun 28, 2008 | 03:47 AM
ZONES89RS's Avatar
In-Zane Moderator
Probably 11.0 give or take.
Old Jul 3, 2008 | 02:12 AM
MrOverkill's Avatar
To save me about a billion key strokes, this is a good read but is mostly stuff I learned long ago...
http://www.hotrod.com/howto/69883_st...ine/index.html
Old Jul 16, 2008 | 01:19 PM
1fastirocz's Avatar
Thanks
