More Problems... Update
Car is also hard to start at times, and will onyl start if given some throttle.
IAC has been replaced.. coolant temp sensor has been replaced.. and the vacuum leaks have been fixed. Hole has been drilled in the TB decently large.. and the idle screw has been adjusted to let more air in.
Any help is once again appreciated.
Only way car will idle is with the idle position screw turned all the way in.. letting lots of air in.. and then when it idles it will surge horrible.. from 300-1200.. wanting to die everytime it falls. With the idle screw in stock position car cranks and immediately dies.
any help is good
-Craig
p.s. i already checked for shop towels in the intake.. j/k
any help is good
-Craig
. I called brother Josh to see if maybe we can get an autotap or hp tuners to borrow, he's going to find out for me tommorow hopefully. In the mean time are theree any sensors that could cause this?? I've tried unplugging the o2's, maf, resetting the pcm and what not. i drove it down the road just and it feels like it clears up when you give it the juice, which it feels like its got a good bit of at that. lol this damn car has been a nightmare. never had half this many problems with a vehicle, but at least now we got it back together
just fixing the bugs is the hard part Thanks
Craig
I got some shop towels you can borrow too
and trust me i got plenty of shop towels, i'm the shop towel king. You should know that... lol
Been down that road, bad idea IMHO. Get a recording of a 15 + min. drive doing everything that represents your driving and send that data to the tuner. Should be a hell of a lot more accurate I'd think.Happy Motorin' !
Not sure.. he told us to just send him the PCm and he'd tune it and send it back.. Alan seems to know his **** tho.
Yea.. the car just cranks and immediately dies.. if we hold the throttle open to keep it idling it'll find idle after like 30 seconds.. and then after another 30 seconds it'll either surge horribly or die.
And about "crunk" sorry.. I've been listening to way too much LiL Jon , nukka.
What would also cause the low RPM miss?
lol hurry up and buy a cam so i can do the shoptowel mod to your motor
lol
Thanks for all the input
Craig
