Slys New Throttle Body
Originally Posted by Crazy Man
Heres some pics of the throttle body I just ported and polished for Sly..Hope you like it man lol ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Just finished epoxying it, clear coating it and put it on. Idles at like 1200 rpm's now so I'll have to tune for it to fix that hopefully. Getting ready to go take it for a test drive to see if it made any difference. Thanks Tim!!!
-Sly
-Sly
Hmmm... Bo do you know if the Truck TB will work? It appears that when you press the throttle to the floor the TB only opens up 3/4 of the way. I'm thinking if I swap out the TB arm that opens the blade from the original one off of my car it should fix it. Does this sound right? Also I'm using the electronics that came off of this TB, I'm assuming the IAC is the same, if not that could be the reason why it idles so high, more like 1500-1700rpms. Tim did you shave away any around the base of the blade??
-Sly
-Sly
Just read this thread...
https://ls1tech.com/forums/showthrea...light=truck+tb
...it appears I need to swap the bellcrank and shaft. Kind of sucks because Tim already polished the one that was on it so it will have an unpolished bell crank.
-Sly
-Sly
Ok, problem fixed, swapped out the bellcrank and TB blade and it fixed all the problems. The TB blade that was in there originally had the hole drilled out larger, must have had it on my other car in the past and forgot thus it was causing it to idle too high.
-Sly
-Sly
Location: sojourning....looking for my city whose builder and maker is God.
Originally Posted by slyws6
yup, just swapped them and it fixed everything, nice SOTP difference, not huge but you can tell, also it feels a little more responsive. Thanks!
-Sly
-Sly
No i need tuning still if that's cool with you, I'm throwing 4 codes, 2 (P0172) and 2 (P0175), after installing the lid and de-screening the MAF.
-Sly
-Sly
