need help with lowering springs
You can take them off without one but then need to go to a shop to have them swapped or use a spring compresoor yourself
Then you can either buy/borrow/rent a spring compressor to hold the spring while you remove it from the strut or you can just take it and the new springs to a shop and have them do it... it can't be too expensive at that point since all the labor is in pulling them not on taking them apart.
Its not real easy to get it all back in and lined up, but its doable.
