Southern Members A regional forum for all our down South members.
Centerville
Old May 6, 2007 | 11:16 AM
  #41
juicedls1's Avatar
Man ur car was moving, my car ran like dog sh*t but i found out what the problem was, so were back to normal now!!! I had fun last night, i prolly wont make it down there in a couple sat though... Shane u still n the pump gas drags?
Old May 6, 2007 | 11:18 AM
  #42
juicedls1's Avatar
Originally Posted by StreetStalkerZ
Any of you little rock guys going to come down and play with us on the 12th at RRR?
I dont think ill be able to make it, ill have to c if i can get a truck and trailor! I wish it wasnt such a lond haul 4 me!!!
Old May 6, 2007 | 01:24 PM
  #43
RDTA's Avatar
I didnt run no record breaking times. Just run a 8.20. with some traction problems. the heads stayed down though.
Old May 7, 2007 | 08:44 PM
  #44
02SSLE's Avatar
If I can get it back together in time. We will see.
Old May 8, 2007 | 10:02 AM
  #45
ThaBirdMan's Avatar
I wanna go....
Old May 12, 2007 | 06:00 AM
  #46
Frank02L's Avatar
Robby, I broke the trans again, and this time while it was down i decided to put a 9" in it instead of the factory 9.75. Multiple reasons, no c clip elims for the 9.75, alot more brakes on the 9", gear selection of the 9", and about 100lbs lighter for the 9"! Plus I changed the traction bar setup on it as well. No more HP yet, just wanna try to get the HP I am making now down to the track consistently.
Oh well, if the weather cooperates we may bring it out this evening to centerville.
Old May 12, 2007 | 02:41 PM
  #47
juicedls1's Avatar
Thats cool frank, ill be down there watching i pulled my filter out on my n20 solenoid and it was plugged up with trash, and my plugs got metallic all over them so i got to get a timing tuner before i run again, im thinking of doin a turbo setup on mine, just dont know if i want to spend the $ yet!!!
Old May 12, 2007 | 03:00 PM
  #48
1cleanbird's Avatar
^do it!
Old May 13, 2007 | 09:42 PM
  #49
02SSLE's Avatar
be ready to drop unlimited money. It seems like every time I turn around I am spending 2 to 3 hundred dollors on something.
Old May 14, 2007 | 06:12 PM
  #50
juicedls1's Avatar
Change of plans going with a 408, setup for a good size n2o shot, my motor is getting noisy, burns oil (1qt per week), and has low oil pressure, so i need a motor first!!!
Old May 14, 2007 | 07:46 PM
  #51
1cleanbird's Avatar
^that's excellent news.
Old May 14, 2007 | 08:37 PM
  #52
juicedls1's Avatar
Yep hopefully in a week or so ill b ordering my complete longblock from TSP, going with the iron block 408 havent decided what cam or heads yet cause itll be built for nitrous, maybe i can run with shane and the others at cville now! Ive got 120,000 out of mine with a sh*t load of n20 ran through it!
Old May 14, 2007 | 09:39 PM
  #53
02SSLE's Avatar
well I ran 11.00 @136 at memphis with 2.0 60ft time so I wasn't to disapointed
Old May 14, 2007 | 11:35 PM
  #54
the_merv's Avatar
Veteran: Air Force
^^ Good ****.
Is that to keep them from having to give you **** about having a Cage..
Old May 15, 2007 | 06:36 AM
  #55
02SSLE's Avatar
Nope they left me alone. I think Hot Rod told them to let me run. That's on a drag radial with 10.2on wideband it was to rich. It was over boosting that morning so I turnd it down some and it was to much. I was running about 11psi vs normal of 15 and it pulls much harder when I adjusted it when we got home.
Old May 15, 2007 | 07:11 AM
  #56
the_merv's Avatar
Veteran: Air Force
Drop a 1.7 60' in there and you got mid 10's..
Old May 15, 2007 | 10:03 AM
  #57
Frank02L's Avatar
I spun the 315/60/15 Mickey Thompsons for a few feet last saturday night and the truck was running poorly. Brought it home, Brian found out the problems Sunday and now we're putting the 10.5s on it so we can run Hot Street next Saturday night. Best 60' sat was a 1.59 spinning and off the footbrake.
