Southern Members A regional forum for all our down South members.
Columbus, GA
Old Mar 23, 2010 | 05:49 PM
  #1801
sheikss's Avatar
Picture sent, the transition in the y isn't to bad.
Old Mar 23, 2010 | 09:46 PM
  #1802
Z51C6's Avatar
Originally Posted by tj1986c
He must've just traded it in recently. He still had it last time I was there.
There was a doctor in town that had a 99 red Hawk, tag read "ER DOC" it may of been his. The one at Jay had cloth int. I think the doc's had leather?
Old Mar 24, 2010 | 03:28 AM
  #1803
firehawk238's Avatar
Ian's had cloth im pretty sure. was beige clothe, or taupe. whatever color they called it then.
Old Mar 24, 2010 | 09:39 PM
  #1804
sheikss's Avatar
What did you think of the y?
Old Mar 25, 2010 | 01:16 AM
  #1805
that Y looked like it was 3" in and 3" out. not a fan of the way the driverside meets into the flow of the passenger side either seems like it would substantially slower flow than the mufflex that uses the merge Y. just my opinion though, and for 500 dollars i definately wouldnt go that route.... you could buy the mufflex, and then just modify the front of it a bit and still come out cheaper, and in my opinion better.
Old Mar 25, 2010 | 12:03 PM
  #1806
more of sheik's hooptie... lol
Old Mar 25, 2010 | 03:59 PM
  #1807
sheikss's Avatar
The y pic I sent was of the y on my 97.
Old Mar 25, 2010 | 04:15 PM
  #1808
ahhh......
Old Mar 25, 2010 | 09:01 PM
  #1809
sheikss's Avatar
http://www.keislerauto.com/recent-ne...k-6-speed.html
This is to pimp, it will handle 1200hp and 1000 tq. The real kicker is that it only cost $2800 from what I was told. Only down side that I can see is that it is noisy, oh well, just means you need a louder exhaust.
Old Mar 25, 2010 | 10:30 PM
  #1810
OUTLAWZ RACING's Avatar
That is a sick transmission lol.
Old Mar 26, 2010 | 07:32 AM
  #1811
greasemonkeysoldier's Avatar
Man that tranny is awesome! its almost too good to be true, lol.
Old Mar 26, 2010 | 11:33 AM
  #1812
it looks to be based off the magnum T56 which has a different shifter location than a 4th gen Fbody. i looked at the model vehicles they make it for, and definately didnt see my car, or the 98-02 cars on the list.....
Old Mar 26, 2010 | 12:01 PM
  #1813
that sucks.....well maybe this technology will catch on and there will be more options in the future....
Old Mar 26, 2010 | 12:49 PM
  #1814
sheikss's Avatar
It's for tremec t56's in general.
Old Mar 26, 2010 | 07:13 PM
  #1815
so i got a jump start on my LT install today....all i have left to do is take the stock manifolds off and then i can get them Hookers up in there and put everything back together.
i have run into a couple of problems though. The front O2 sensor on the drivers side does NOT want to come out. is it safe to spray some penetrating fluid on it?
also, i can't get the steering linkage off to save my life, any tips/hints?
Old Mar 26, 2010 | 07:42 PM
  #1816
Make sure the steering link is straight and both bolts are completly out. Spray some w d on the top end and use a fork or screw driver to pry it up from the rack. You have to go up then down to get it off. W d is safe for the o2 housing it wont leak past the treads enough to get on the sensor. Also if your going long tubes I would not use o2 extension they are shitty. The bosch 02 Part# 13111 for a 98-2002 c5 rear o2 pig tails are long enough to reach they are alittle pricey but the will work. I use them on all my header jobs with no issue.
Old Mar 26, 2010 | 08:05 PM
  #1817
ahhh...see...thats where my problem was with the steering linkage. the how-to guide i was using for reference just said to go down. but going up first makes sense...i should be good on that....and i'll spray the threads on the O2's since its safe. thanks...
Old Mar 26, 2010 | 08:25 PM
  #1818
No problem bro . Yeah once you get it off you will see that little nipple is not long enough to do it like that. You have to slide it up lol.
Old Mar 27, 2010 | 01:41 AM
  #1819
CancerJCC's Avatar
Just happened to hop into this section by random. I own an 04 CTS-V and reside in Phenix City ATM. Do you guys do any meets? (It seems just a few guys posting for the last few pages).
Old Mar 27, 2010 | 08:04 AM
  #1820
sheikss's Avatar
zz, fire, and me meet up and hangout quiet a bit. We help each other out when it comes to working on our cars
