1997 Camaro SS
Standard SS parts that SLP installed on all SS
hood
SS air filter box and tubing
air filter base block off plate (went in the old location of Z28 style air tubing)
SS badging
SS interior plaque
ZR1 wheels with SS logo center caps
SS spoiler
SS owners supplement manual
Optional SLP equipment
Hurst shifter with leather H ****
2 on the left catback
Castrol lubricant package
Bilstein suspension package
SS car cover
SS floor mats
SS key chain
R1 rear tire package (2 extra rear wheels with R1 slicks)
There's a few other small things here and there that I'm forgotten since it's been a long time but this takes care of 99% of it.
The R7T was the RPO code for the SS package in 1997 . . .
The R7A was a SLP option code . .
The WU8 was linked to the SS package . . . .
The WU9 was linked to the 30th Anniversary SS package . .
My best guess to clairfy the info I have found . . .
R7T and WU8 are on 1997 SS's
R7A and WU9 are on 1997 30th Anniversary SS'sI broke Down my RPO Code list, from inforamtion I found on the net and Mr. Hamburger . .
1997 30th Anniversary SS LT4 RPO Codes
AG1 - Power Driver's Seat
AK5 - Inflatable Driver and Passenger Air Bag
AR9 - Deluxe Front Bucket
AU0 - Remote Keyless Entry
AU3 - Electric Door Locks
A31 - Power Windows
A90 - Power Deck Lid Release
B35 - Carpeted Floor Mats
B84 - Exterior Moldings
CAE - Handling Charge From St. Therese to SLP
C49 - Rear Window Defogger
C60 - Air Conditioner w/ Manual Controls
DG7 - Body Colored Electric Remote Controlled Mirrors
DL5 - Roadside Assistance Decal
FE2 - Ride Handling Suspension
FE9 - Federal Emissions
GU6 - 3:42 Rear Axle Gear Ratio
G80 - Limited Slip Rear Axle
IPC - PC Interior Trim Design (forcing the two tone seats)
J65 - Power Front and Rear Disc Brakes
KG9 - 140 Amp Alternator
K34 - Electronic Cruise Control
LT1 - MFI HO 5.7 Liter V8 Engine
MM6 - Tremec Manual 6 Speed Trans 85 mm, 2.66 1st and 0.50 O/D
MN6 - Manual 6 Speed Provisions
NF2 - Tier 1 Federal Emissions
NP5 - Leather Wrapped Steering Wheel
PE0 - 16" x 8" Lightweight Styled Aluminum Wheels
QLC - Tire P245/50R16 N BL R/PE ST TL HW4
R7A - Sales Item #26
STE - Plant Code St. Therese
T82 - Automatic On/Off Head Lamps
T96 - Front Fog Lamps
UA6 - Theft Deterrent System
UB3 - Instrument Cluster, Oil, Volts, Tach
UL0 - AM/FM Cassette
UZ7 - 8 Speaker, Quad Front Dr. Mounted, Sail Panel, Dual RR Hatch & Amplifier
U1S - Multiple Compact Disc Player
U73 - Fixed Mast Antenna
V73 - USA/Canada Vehicle Statement
WU9 - 30th Anniversary Camaro SS Appearance and Performance Sales Package
Z28 - Special Performance Sales Package
Z4C - 30th Anniversary Package
1AY - Stock Order Modification
1SJ - Option 9 Package (Z28 Preferred Equipment Package #2)
1SZ - Option Package Discount
10C - Arctic White (Houndstooth) Cloth Trim Combination
10I - Arctic White Interior Trim
10Q - Arctic White Molding Color
10U - Arctic White Exterior Color
6HD - Computer Select Susp. Component Front LH
7HD - Computer Select Susp. Component Front RH
8TH - Computer Select Susp. Component Rear LH
9TH - Computer Select Susp. Compoent Rear RH
The only 4th Gen Camaros that I ever recall getting embroidered seats was the 1997 30th and 2002 35th anniversaries . . .
